From @DavidBooher on Wed Jan 27 2016 00:44:43 GMT+0000 (UTC)
Version: 0.3.10
Fuse: 2.8.3
jimbo:.ipfs dbooher$ ipfs config DontCheckOSXFUSE true
jimbo:.ipfs dbooher$ ipfs daemon --mount
Initializing daemon…
Swarm listening on /ip4/172.16.144.1/tcp/4001
Swarm listening on /ip4/192.168.22.200/tcp/4001
Swarm listening on /ip4/192.168.89.1/tcp/4001
Swarm listening on /ip4/73.44.241.86/tcp/15950
Swarm listening on /ip4/73.44.241.86/tcp/64096
Gateway (readonly) server listening on /ip4/127.0.0.1/tcp/8080
18:37:36.343 ERROR swarm2: swarm listener accept error: peerstream listener failed: accept tcp 0.0.0.0:4001: use of closed network connection swarm_listen.go:129
Error: config key invalid: DontCheckOSXFUSE %!s(bool=true)
You may be able to get this error to go away by setting it again:
Either way, please tell us at: GitHub · Where software is built
jimbo:bin dbooher$ ipfs config DontCheckOSXFUSE true
Error: Failed to set config value: Wrong config type, expected bool (maybe use --json?)
jimbo:bin dbooher$
Copied from original issue: Setting DontCheckOSXFUSE true does not seem to work · Issue #18 · ipfs-inactive/support · GitHub
