Hello everyone,
I’m just getting started with IPFS and had a few questions, although I’ll just start with the first one for now.
If I had a file using the UI, I can see the hash doing:
ipfs refs local
But I can not see it if I do:
ipfs pin ls
Just as if I add a file from the command line, which I think I read pins it by default, it doesn’t now show in the UI under files as a file being shared.
How come these are disconnected? Are the files for the UI going somewhere else other than my normal repo?
Thank you,
Nate
