Storing a few TB of data?
From @e12e on Sun Apr 05 2015 20:45:50 GMT+0000 (UTC)
If I push a few TB of data into ipfs (say some media files, install isos etc) – is that a reasonable use of the technology? How could/should I assure that the network has the capacity to safely store the data, with suitable redundancy? If I dedicate a few TB of disk on my server to ipfs – can I make sure that some sensible portion is reserved for my use?
Copied from original issue: Storing a few TB of data? · Issue #5 · ipfs-inactive/faq · GitHub
From @whyrusleeping on Mon Apr 06 2015 00:07:02 GMT+0000 (UTC)
Data added to ipfs is only stored locally until another interested party requests it from you. ipfs itself (the protocol) provides no guarantees of redundancy or remote storage.
From @jbenet on Mon Apr 06 2015 03:00:18 GMT+0000 (UTC)
I’ll add that that’s why Filecoin exists-- as a way to incentivize networks of people to replicate/backup your data.
From @sudhirj on Thu Dec 03 2015 18:09:57 GMT+0000 (UTC)
BTW, could someone confirm that ipfs add makes a copy of the data I’m adding? So to add 1TB of data into IPFS I’ll need at least 2 TB on my disk?
From @whyrusleeping on Thu Dec 03 2015 18:18:55 GMT+0000 (UTC)
@sudhirj that is correct. Similar to adding files into git, in the future we may find a way to work around this.
From @sudhirj on Fri Dec 04 2015 13:59:30 GMT+0000 (UTC)
Okay. Then let’s put down alternative options for others as well (I’m looking at it for large-file data distribution). The alternatives to this are
  1. Mount the IPFS datastore as a FUSE drive (requires root permissions and special installation) - will this take care of everything automatically? Is copying a file into the mounted folder same as ipfs add, for instance?
  2. Assuming a FUSE mount, can regular IPFS commands like ipfs pin be used on data on the mounted drive?
