Subdomain CNAME linked to an IPFS CID with HTTPS?
Hi !
As this tutorial:
I created a subdomain linked to an IPFS CID by DNS CNAME and TXT.
All is ok if I access to the subdomain url with “http” protocol, but dont work if I try with the “https”.
The domain of subdomain has a Lets encryptcertificate and works resolve to “https”.
Why the subdomain dont work securelly with “https” access ?
Thanks
Do you run your own gateway or do you use a public one?
If running your own, does it have a tls cert for your subdomain?
I am used the document gateway not mine
I think that use a gateway in my server is the same that host files in my server if my server is hacked…
The point is, the gateway you are using must have a tls cert for your subdomain, or you can’t use https with it.
Do you know any service for it?
Thank you ylempereur
I use Fleek for my sites, but there are several others that do similar things as well.
<3
