Hello everybody,
I recently discovered about Gossipsub. I would like to play a bit with it, to see whether it can suit my project.
I did not find any information on how to use gossipsub with the IPFS client. I guess this is not possible to do, right?
Is the only way to test it using the dedicated go or js libraries? Are there any tutorials or documentation out there that could be used to start?
Thanks a lot !
