Use StaticRelays
I have 3 nodes, A, B, C. Node A has a public network ip. A node configuration is as follows
A:
  "Identity": {
    "PeerID": "12D3KooWDzkEohDABVk6fUMRENaX1CWUcLLKLrew4X5aB7NvX6eZ",
    "PrivKey": "CAESQHfwiEmnoLUlHsr60PXHL/QyR54fLeaxyQNwPh6Z878QPheCrQNIXR1IYOnXna1GCAQFZhwyVmTaFVJ3gGWm/NY="
  "Addresses": {
    "Swarm": [
      "/ip4/0.0.0.0/tcp/4001",
      "/ip6/::/tcp/4001",
      "/ip4/0.0.0.0/udp/4001/quic",
      "/ip6/::/udp/4001/quic",
      "/ip6/::/udp/4001/quic-v1",
    "Announce": [],
    "AppendAnnounce": [],
    "NoAnnounce": [],
    "Gateway": "/ip4/127.0.0.1/tcp/8080"
  "Mounts": {
    "IPFS": "/ipfs",
    "IPNS": "/ipns",
    "FuseAllowOther": false
  "Discovery": {
    "MDNS": {
      "Enabled": true
  "Routing": {
    "Routers": null,
    "Methods": null
  "Ipns": {
    "RepublishPeriod": "",
    "RecordLifetime": "",
    "ResolveCacheSize": 128
  "Bootstrap": [
  "Gateway": {
    "HTTPHeaders": {
        "X-Requested-With",
        "Range",
        "User-Agent"
        "GET"
    "RootRedirect": "",
    "Writable": false,
    "PathPrefixes": [],
    "APICommands": [],
    "NoFetch": false,
    "NoDNSLink": false,
    "PublicGateways": null
  "API": {
    "HTTPHeaders": {}
  "Swarm": {
    "AddrFilters": null,
    "DisableNatPortMap": false,
    "RelayClient": {},
    "RelayService": {},
    "Transports": {
      "Network": {},
      "Security": {},
      "Multiplexers": {}
    "ConnMgr": {},
    "ResourceMgr": {}
Both nodes B and C are behind NAT
B:
  "Identity": {
    "PeerID": "12D3KooWR1DDhp7obaSRfdC6TTSURYs5S23f8ithS79npmnY1j7b",
    "PrivKey": "CAESQADvqMn0RvVqGPXmzA63uV2EJur3bea5t8SBJcRLlIMm4aaS/K43JHX1PPr7ONwrehb0BY9k7sA/gqjeO3NhaPY="
  "Addresses": {
    "Swarm": [
      "/ip6/::/tcp/4001",
    "Announce": [],
    "NoAnnounce": [],
  "Mounts": {
    "IPFS": "/ipfs",
    "IPNS": "/ipns",
  "Discovery": {
    "MDNS": {
      "Enabled": true
  "Routing": {
    "Routers": null,
    "Methods": null
  "Ipns": {
  "Bootstrap": [
    "/ip4/104.131.131.82/udp/4001/quic/p2p/QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ"
  "Gateway": {
    "HTTPHeaders": {
        "X-Requested-With",
        "Range",
        "User-Agent"
        "GET"
    "RootRedirect": "",
    "Writable": false,
    "PathPrefixes": [],
    "APICommands": [],
    "NoFetch": false,
    "NoDNSLink": false,
  "API": {
    "HTTPHeaders": {}
  "Swarm": {
    "RelayClient": {
      "StaticRelays": [
        "/ip4/1.14.49.178/tcp/4001/p2p/12D3KooWDzkEohDABVk6fUMRENaX1CWUcLLKLrew4X5aB7NvX6eZ"
    "RelayService": {},
    "Transports": {
      "Network": {},
      "Security": {},
      "Multiplexers": {}
    "ConnMgr": {},
    "ResourceMgr": {}
C:
  "Identity": {
    "PeerID": "12D3KooWQy7qrxKo918uTPmVMnewDGHmUzMFL8MHcWJTfZoZhXCr",
    "PrivKey": "CAESQML3S2ePs41VqTkQBZdVFnNOGom+g+2IohhR+YwtCbun4R1VTbU9AcmpaDH0v2jTGuKHUZHvIqTcQZgG+nazPuc="
  "Addresses": {
    "Swarm": [
      "/ip6/::/tcp/4001",
    "Announce": [],
    "NoAnnounce": [],
  "Mounts": {
    "IPFS": "/ipfs",
    "IPNS": "/ipns",
  "Discovery": {
    "MDNS": {
      "Enabled": true
  "Routing": {
    "Routers": null,
    "Methods": null
  "Ipns": {
  "Bootstrap": [
    "/ip4/104.131.131.82/udp/4001/quic/p2p/QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ",
  "Gateway": {
    "HTTPHeaders": {
        "X-Requested-With",
        "Range",
        "User-Agent"
        "GET"
    "RootRedirect": "",
    "Writable": false,
    "PathPrefixes": [],
    "APICommands": [],
    "NoFetch": false,
    "NoDNSLink": false,
  "API": {
    "HTTPHeaders": {}
  "Swarm": {
    "RelayClient": {
      "StaticRelays": [
    "RelayService": {},
    "Transports": {
      "Network": {},
      "Security": {},
      "Multiplexers": {}
    "ConnMgr": {},
    "ResourceMgr": {}
The node information of B and C are as follows
B:
ipfs id
        "ID": "12D3KooWR1DDhp7obaSRfdC6TTSURYs5S23f8ithS79npmnY1j7b",
        "PublicKey": "CAESIOGmkvyuNyR19Tz6+zjcK3oW9AWPZO7AP4Ko3jtzYWj2",
        "Addresses": [
                "/ip4/1.14.49.178/tcp/4001/p2p/12D3KooWDzkEohDABVk6fUMRENaX1CWUcLLKLrew4X5aB7NvX6eZ/p2p-circuit/p2p/12D3KooWR1DDhp7obaSRfdC6TTSURYs5S23f8ithS79npmnY1j7b",
                "/ip4/1.14.49.178/udp/4001/quic-v1/p2p/12D3KooWDzkEohDABVk6fUMRENaX1CWUcLLKLrew4X5aB7NvX6eZ/p2p-circuit/p2p/12D3KooWR1DDhp7obaSRfdC6TTSURYs5S23f8ithS79npmnY1j7b",
                "/ip4/1.14.49.178/udp/4001/quic/p2p/12D3KooWDzkEohDABVk6fUMRENaX1CWUcLLKLrew4X5aB7NvX6eZ/p2p-circuit/p2p/12D3KooWR1DDhp7obaSRfdC6TTSURYs5S23f8ithS79npmnY1j7b",
                "/ip4/127.0.0.1/tcp/4001/p2p/12D3KooWR1DDhp7obaSRfdC6TTSURYs5S23f8ithS79npmnY1j7b",
                "/ip4/127.0.0.1/udp/4001/quic/p2p/12D3KooWR1DDhp7obaSRfdC6TTSURYs5S23f8ithS79npmnY1j7b",
                "/ip4/192.168.1.4/tcp/4001/p2p/12D3KooWR1DDhp7obaSRfdC6TTSURYs5S23f8ithS79npmnY1j7b",
        "AgentVersion": "kubo/0.18.0/",
C:
ipfs id
        "ID": "12D3KooWQy7qrxKo918uTPmVMnewDGHmUzMFL8MHcWJTfZoZhXCr",
        "PublicKey": "CAESIOEdVU21PQHJqWgx9L9o0xrih1GR7yKk3EGYBvp2sz7n",
        "Addresses": [
                "/ip4/1.14.49.178/tcp/4001/p2p/12D3KooWDzkEohDABVk6fUMRENaX1CWUcLLKLrew4X5aB7NvX6eZ/p2p-circuit/p2p/12D3KooWQy7qrxKo918uTPmVMnewDGHmUzMFL8MHcWJTfZoZhXCr",
                "/ip4/1.14.49.178/udp/4001/quic-v1/p2p/12D3KooWDzkEohDABVk6fUMRENaX1CWUcLLKLrew4X5aB7NvX6eZ/p2p-circuit/p2p/12D3KooWQy7qrxKo918uTPmVMnewDGHmUzMFL8MHcWJTfZoZhXCr",
                "/ip4/1.14.49.178/udp/4001/quic/p2p/12D3KooWDzkEohDABVk6fUMRENaX1CWUcLLKLrew4X5aB7NvX6eZ/p2p-circuit/p2p/12D3KooWQy7qrxKo918uTPmVMnewDGHmUzMFL8MHcWJTfZoZhXCr",
                "/ip4/127.0.0.1/tcp/4001/p2p/12D3KooWQy7qrxKo918uTPmVMnewDGHmUzMFL8MHcWJTfZoZhXCr",
                "/ip4/127.0.0.1/udp/4001/quic-v1/p2p/12D3KooWQy7qrxKo918uTPmVMnewDGHmUzMFL8MHcWJTfZoZhXCr",
I want to connect B and C to each other through A node, and then they can transfer files to each other.
when i execute the commandipfs swarm connect /ip4/1.14.49.178/udp/4001/quic-v1/p2p/12D3KooWDzkEohDABVk6fUMRENaX1CWUcLLKLrew4X5aB7NvX6eZ/p2p-circuit/p2p/12D3KooWQy7qrxKo918uTPmVMnewDGHmUzMFL8MHcWJTfZoZhXCr but there is no result, no error and no connection to the target node
When I do not specify the relay point, the two points behind NAT can connect to each other and transfer files
It looks like you’re trying to use CircuitRelayV1 (full relaying), which was deprecated in Kubo v0.11.0 unfortunately. So to test out what you’re trying, you’d need v0.10.x or earlier. In newer version of Kubo, the circuit-relay v2 is used “under-the-hood” to assist in automatic hole-punching for users behind NAT to achieve connections.
