I recently install and am using the Brave browser’s ipfs capability. It works well under the browser. I can enter ipfs://whatever and get the file I’m looking for.
Since Brave is running IPFS locally on my machine (I selected that option the first time I opened a file), I wonder if it would be possible to use IPFS on my command line.
I found the running ipfs node (in ~/Library/Application Support/BraveSoftware/Brave-Browser/nljcddpbnaianmglkpkneakjaapinabi/1.0.3/go-ipfs_v0.7.0_darwin-amd64) and perhaps I can just point my IPFS_PATH to some folder?
When I try ipfs get whatever from my command line, it says my IPFS repo is not initalized.
Any ideas?
