Workflow for hacking on go-ipfs dependencies?
I’ve added some features to go-multiaddr (and go-mutliaddr-net) and would like to test my changes with go-ipfs (ipfs executable). However, I can’t seem to figure out a good way of making go-ipfs point to my local git repositories rather than to their ipfs hash. I’ve tried using sed to replace all occurences of gx/ipfs/<go-multiaddr-hash> with github.com/multiformats but this results in the following kinds of errors:
exchange/bitswap/network/ipfs_impl.go:36:38: cannot use (*netNotifiee)(&bitswapNetwork) (type *netNotifiee) as type net.Notifiee in argument to host.Network().Notify:
	*netNotifiee does not implement net.Notifiee (wrong type for Listen method)
		have Listen(net.Network, "github.com/multiformats/go-multiaddr".Multiaddr)
		want Listen(net.Network, "gx/ipfs/QmWWQ2Txc2c6tqjsBpzg5Ar652cHPGNsQQp2SejkNmkUMb/go-multiaddr".Multiaddr)
Does this mean I’ll have to recursively replace the hash in all dependencies, and if so, how? Surely there must be a better way. What workflows do the ipfs developers use? I hope it is not required to upload modified dependencies to ipfs in order to use them locally.
So, we use a tool called gx to manage our dependencies. In this case, you want to use the gx-go link command.
cd $GOPATH/src/github.com/ipfs/go-ipfs
# install gx (if you don't have it)
go get github.com/whyrusleeping/gx
go get github.com/whyrusleeping/gx-go
# install the deps (if you don't yet have them)
gx install
# Find the current version of go-multiaddr being used
gx deps -r  | grep go-multiaddr
# Replace the multiaddr dep
# NOTE: This will modify your source code in github.com/multiformats/go-multiaddr. It'll replace the github.com/... paths with gx/... paths.
gx-go link $HASH
You can undo the link by running:
gx-go link -r -a # remove all linked deps
You can undo the modifications to the go-multiaddr library by running:
cd $GOPATH/src/github.com/multiformats/go-multiaddr
gx-go rw --fix # unrewrite the paths from the gx/... form to the github.com/... form
rm ./.gx/post-install # marker file we create when we "install" a gx package.
(you may be interested in this thread: https://github.com/ipfs/go-ipfs/issues/4831)
Thanks! It worked.
I hadn’t understood that gx-go was a tool one needs to call explicitly. I thought it was just a package which provided go hooks for gx.
I was even able to do:
gx-go link go-multiaddr{,-net}
which is a bit nicer than having to copy and paste the hashes.
I can’t say I’m a big fan of gx right now given how it messes up my working trees and hard codes dependencies in all dependant source files (rather than having a central dependency file, which would IMHO be a much saner design), but I’ll make do.
In general, you don’t have to call it. Only for special cases like this.
I’ve had bad experiences using package names with gx so I don’t by policy (bugs…). But yeah, that should work.
I agree. I’d like to do what NPM does (except use hashes instead of versions when “locking” dependencies). Unfortunately, this takes time.
On the other hand, modifying a single gx dependency does wonders for my github activity…
