I got some warning, want to know need fix them or not?
$ yarn add ipfs-core
yarn add v1.19.2
[1/4] 🔍 Resolving packages...
warning ipfs-core > libp2p-webrtc-star > socket.io > debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
warning ipfs-core > libp2p-webrtc-star > socket.io > engine.io > debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
warning ipfs-core > libp2p-webrtc-star > socket.io > socket.io-parser > debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
[2/4] 🚚 Fetching packages...
[3/4] 🔗 Linking dependencies...
warning " > @testing-library/user-event@12.8.3" has unmet peer dependency "@testing-library/dom@>=7.21.4".
[4/4] 🔨 Building fresh packages...
success Saved lockfile.
