### Checklist
- [X] This is a bug report, not a question. Ask questions on [d…iscuss.ipfs.io](https://discuss.ipfs.io).
- [X] I have searched on the [issue tracker](https://github.com/ipfs/go-ipfs/issues?q=is%3Aissue) for my bug.
- [X] I am running the latest [go-ipfs version](https://dist.ipfs.io/#go-ipfs) or have an issue updating.
### Installation method
built from source
### Version
```Text
go-ipfs version: 0.13.0-dev-2a871ef01
Repo version: 12
System version: amd64/linux
Golang version: go1.17.6
### Config
<details>
```json
"API": {
"HTTPHeaders": {}
"Addresses": {
"Announce": [],
"AppendAnnounce": null,
"Gateway": "/ip4/127.0.0.1/tcp/80",
"NoAnnounce": [
"/ip4/10.0.0.0/ipcidr/8",
"/ip4/100.64.0.0/ipcidr/10",
"/ip4/169.254.0.0/ipcidr/16",
"/ip4/172.16.0.0/ipcidr/12",
"/ip4/192.0.0.0/ipcidr/24",
"/ip4/192.0.0.0/ipcidr/29",
"/ip4/192.0.0.8/ipcidr/32",
"/ip4/192.0.0.170/ipcidr/32",
"/ip4/192.0.0.171/ipcidr/32",
"/ip4/192.0.2.0/ipcidr/24",
"/ip4/192.168.0.0/ipcidr/16",
"/ip4/198.18.0.0/ipcidr/15",
"/ip4/203.0.113.0/ipcidr/24",
"/ip4/240.0.0.0/ipcidr/4",
"/ip6/100::/ipcidr/64",
"/ip6/2001:2::/ipcidr/48",
"/ip6/2001:db8::/ipcidr/32",
"/ip6/fc00::/ipcidr/7",
"/ip6/fe80::/ipcidr/10"
"Swarm": [
"/ip4/0.0.0.0/tcp/443",
"/ip6/::/tcp/443",
"/ip4/0.0.0.0/udp/443/quic",
"/ip6/::/udp/443/quic"
"AutoNAT": {},
"Bootstrap": [
"/ip4/104.131.131.82/udp/4001/quic/p2p/QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ"
"DNS": {
"Resolvers": null
"Datastore": {
"BloomFilterSize": 0,
"GCPeriod": "1h",
"HashOnRead": false,
"Spec": {
"mounts": [
"child": {
"path": "blocks",
"sync": false,
"type": "flatfs"
"mountpoint": "/blocks",
"prefix": "flatfs.datastore",
"type": "measure"
"child": {
"compression": "none",
"path": "datastore",
"type": "levelds"
"mountpoint": "/",
"type": "measure"
"type": "mount"
"StorageGCWatermark": 90,
"StorageMax": "500GB"
"Discovery": {
"MDNS": {
"Enabled": false,
"Interval": 10
"Experimental": {
"FilestoreEnabled": false,
"GraphsyncEnabled": false,
"P2pHttpProxy": false,
"StrategicProviding": false,
"UrlstoreEnabled": false
"Gateway": {
"APICommands": [],
"HTTPHeaders": {
"X-Requested-With",
"Range",
"User-Agent"
"GET"
"NoDNSLink": false,
"NoFetch": false,
"PathPrefixes": [],
"PublicGateways": null,
"RootRedirect": "",
"Writable": false
"Identity": {
"PeerID": "xxx"
"Internal": {},
"Ipns": {
"RecordLifetime": "96h",
"RepublishPeriod": "",
"ResolveCacheSize": 2048
"Migration": {
"DownloadSources": null,
"Keep": ""
"Mounts": {
"FuseAllowOther": false,
"IPFS": "/ipfs",
"IPNS": "/ipns"
"Peering": {
"Peers": null
"Pinning": {},
"Plugins": {
"Plugins": null
"Provider": {
"Strategy": ""
"Pubsub": {
"DisableSigning": false,
"Router": "gossipsub"
"Reprovider": {
"Interval": "12h",
"Strategy": "all"
"Routing": {
"Type": "dhtserver"
"Swarm": {
"AddrFilters": [
"ConnMgr": {
"GracePeriod": "3m",
"HighWater": 700,
"LowWater": 500,
"Type": "basic"
"DisableNatPortMap": true,
"RelayClient": {},
"RelayService": {},
"Transports": {
"Multiplexers": {},
"Network": {
"QUIC": false
"Security": {}
</details>
### Description
I'm running 2a871ef01 compiled by go 1.17.6 on Arch Linux for some days on one of my servers.
I had trouble with my MFS datastore after updating (I couldn't delete a file). So I reset my datastore and started importing the data again.
I'm using a shell script that adds the files and folders individually. Because of #7532, I can't use `ipfs files write` but instead use `ipfs add`, followed by an `ipfs files cp /ipfs/$cid /path/to/file` and an `ipfs pin rm $cid`.
For the `ipfs add` is set `size-65536` as the chunker, `blake2b-256` as the hashing algorithm, and use raw-leaves.
After the 3 days, there was basically no IO on the machine and ipfs was using around 1.6 cores pretty consistently without any progress real progress. At that time only this one script was running against the API with no concurrency. The automatic garbage collector of ipfs is off.
There are no experimental settings activated and I'm using flatfs.
I did some debugging, all operations were still working, just extremely slow:
$ time /usr/sbin/ipfs --api=/ip4/127.0.0.1/tcp/5001 files stat --hash --offline /x86-64.archlinux.pkg.pacman.store/community
bafybeianfwoujqfauris6eci6nclgng72jttdp5xtyeygmkivzyss4xhum
real 0m59.164s
user 0m0.299s
sys 0m0.042s
and
$ time /usr/sbin/ipfs --api=/ip4/127.0.0.1/tcp/5001 files stat --hash --offline --with-local /x86-64.archlinux.pkg.pacman.store/community
bafybeie5kkzcg6ftmppbuauy3tgtx2f4gyp7nhfdfsveca7loopufbijxu
Local: 20 GB of 20 GB (100.00%)
real 4m55.298s
user 0m0.378s
sys 0m0.031s
This is while my script was still running on the API and waiting minutes on each response.
Here's my memory dump etc. while the issue occurred: /ipfs/QmPJ1ec2CywWLFeaHFaTeo6g56S5Bqi3g3MEF1a3JrL8zk
Here's a dump after I stopped the import of files and the CPU usage dropped down to like 0.3 cores: /ipfs/QmbotJhgzc2SBxuvGA9dsCFLbxd836QBNFYkLhdqTCZwrP
Here's what the memory looked like as the issue occurred (according to `atop 1`):
MEM
tot 31.4G
free 6.6G
cache 1.1G
dirty 0.1M
buff 48.9M
slab 7.1G
slrec 3.7G
shmem 2.0M
shrss 0.0M
vmbal 0.0M
zfarc 15.6G
hptot 0.0M
hpuse 0.0M
The machine got 10 dedicated cores from a AMD EPYC 7702 and 1 TB SSD storage via NAS.
