Good morning,
in my private IPFS network I have a gateway connected to other IPFS nodes. I would like to be able to measure the amount of data passing between the gateway to each of the nodes on the network. Can anyone give me a suggestion on how to implement this functionality?
You can look at bitswap stats with ipfs stats bw.
Alternatively, if you just want to know about blocks exchanged, you can get the current “ledger” for a peer with ipfs bitswap ledger. However, this is cleared on disconnect.
