IPFS monitoring options
From @aronayne on Tue Oct 18 2016 14:06:48 GMT+0000 (UTC)
Using the webui GitHub - ipfs/ipfs-webui: A frontend for an IPFS Kubo and IPFS Desktop seems using the webui can the following be accessed :
  • the number of connected nodes ?
  • the hash values stored on each node ?
  • IP address of machine participating in network ?
And/or can this data be access via the IPFS cli ?
Copied from original issue: IPFS monitoring options · Issue #187 · ipfs-inactive/faq · GitHub
From @Kubuxu on Tue Oct 18 2016 15:02:42 GMT+0000 (UTC)
Yes:
  • number of connected nodes: ipfs swarm peers | wc -l
  • I don’t know right now.
  • check ipfs id
From @lgierth on Tue Oct 18 2016 17:18:30 GMT+0000 (UTC)
You can also query http://localhost:5001/debug/metrics/prometheus to get more runtime metrics
