ipfs version: 0.8.0
Hi everyone,
this is an often requested question but I still couldn’t find help in the existing threads so far. My IPFS node runs on a dedicated machine in my intranet, let’s say it’s found here: 192.168.1.2.
The node has plenty of peers, see ipfs swarm peers and I can locally access the webui.
I understand the following settings must be met in order to access the node from another machine int the intranet:
ipfs config Addresses.API /ip4/0.0.0.0/tcp/5001
ipfs config Addresses.Gateway /ip4/0.0.0.0/tcp/9001
ipfs config --json API.HTTPHeaders.Access-Control-Allow-Origin '["*"]'
I don’t expose the machine to the public, so this is fine with me.
However, I still cannot access the webui from any other machine in my intranet. When calling http:///192.168.1.2:5001/webui it simply gets a
--2021-05-22 14:37:02-- http://192.168.1.2:5001/webui
Connecting to 192.168.1.2:5001... failed: Connection refused.
I don’t know what else to check for and any help would be appreciated.
The machine is of course reachable and I can ssh into it without problems.
Greetings
config:
"API": {
"HTTPHeaders": {
"Addresses": {
"Announce": [],
"Gateway": "/ip4/0.0.0.0/tcp/9001",
"NoAnnounce": [],
"Swarm": [
"/ip4/0.0.0.0/tcp/4001",
"/ip6/::/tcp/4001",
"/ip4/0.0.0.0/udp/4001/quic",
"/ip6/::/udp/4001/quic"
"AutoNAT": {},
"Bootstrap": [
"/ip4/104.131.131.82/udp/4001/quic/p2p/QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ"
"Datastore": {
"BloomFilterSize": 0,
"GCPeriod": "1h",
"HashOnRead": false,
"Spec": {
"mounts": [
"child": {
"path": "blocks",
"sync": true,
"type": "flatfs"
"mountpoint": "/blocks",
"prefix": "flatfs.datastore",
"type": "measure"
"child": {
"compression": "none",
"path": "datastore",
"type": "levelds"
"mountpoint": "/",
"type": "measure"
"type": "mount"
"StorageGCWatermark": 90,
"StorageMax": "10GB"
"Discovery": {
"MDNS": {
"Enabled": true,
"Interval": 10
"Experimental": {
"FilestoreEnabled": false,
"GraphsyncEnabled": false,
"P2pHttpProxy": false,
"ShardingEnabled": false,
"StrategicProviding": false,
"UrlstoreEnabled": false
"Gateway": {
"APICommands": [],
"HTTPHeaders": {
"X-Requested-With",
"Range",
"User-Agent"
"GET"
"NoDNSLink": false,
"NoFetch": false,
"PathPrefixes": [],
"PublicGateways": null,
"RootRedirect": "",
"Writable": false
"Identity": {
"PeerID": "12D3KooWBRs3jikJbyT5dQtXmDS2YkRqtP3n1VHTuTU9zjHwmsQc",
"PrivKey": "CAESQKesMdfRQQqLL0YxJhjVvBWXUT2nKG6xUfbzaF6PRhsgF/OrRpv95aFbZzCR9H28mMNiobMWH7E31FhGyqj3+6E="
"Ipns": {
"RecordLifetime": "",
"RepublishPeriod": "",
"ResolveCacheSize": 128
"Mounts": {
"FuseAllowOther": false,
"IPFS": "/ipfs",
"IPNS": "/ipns"
"Peering": {
"Peers": null
"Pinning": {
"RemoteServices": {}
"Plugins": {
"Plugins": null
"Provider": {
"Strategy": ""
"Pubsub": {
"DisableSigning": false,
"Router": ""
"Reprovider": {
"Interval": "12h",
"Strategy": "all"
"Routing": {
"Type": "dht"
"Swarm": {
"AddrFilters": null,
"ConnMgr": {
"GracePeriod": "20s",
"HighWater": 900,
"LowWater": 600,
"Type": "basic"
"DisableNatPortMap": false,
"EnableAutoRelay": false,
"EnableRelayHop": false,
"Transports": {
"Multiplexers": {},
"Network": {},
"Security": {}
