Hi!
After adding a third member to my IPFS cluster, adding with wait flag has started to fail like:
${IPFS_CLUSTER_CTL} add --wait --quieter --format car ${CONTENT_CAR}
panic: interface conversion: multiaddr.Multiaddr is nil, not *multiaddr.multiaddr
goroutine 23 [running]:
github.com/multiformats/go-multiaddr.(*multiaddr).UnmarshalJSON(0xc000410360, {0xc0002b64fc, 0x5f, 0x304})
github.com/multiformats/go-multiaddr@v0.6.0/multiaddr.go:105 +0xe8
github.com/ipfs-cluster/ipfs-cluster/api.(*Multiaddr).UnmarshalJSON(0xc001234850, {0xc0002b64fc, 0x5f, 0x304})
github.com/ipfs-cluster/ipfs-cluster@v1.0.2/api/types.go:528 +0x74
encoding/json.(*decodeState).literalStore(0xc000430630, {0xc0002b64fc, 0x5f, 0x304}, {0xe9dca0?, 0xc001234850?, 0x197?}, 0x0)
encoding/json/decode.go:871 +0x1f2c
No idea why....
I have verified that each peer in the cluster see the other 2, so, I assume the cluster is well formed.
What could be going on?
