Hello Hector,
This is the default IPFS Desktop config file:
"API": {
"HTTPHeaders": {}
"Addresses": {
"API": "/ip4/127.0.0.1/tcp/5001”,
"Announce": [],
"AppendAnnounce": [],
"Gateway": "/ip4/127.0.0.1/tcp/8080”,
"NoAnnounce": [],
"Swarm": [
"/ip4/0.0.0.0/tcp/4001”,
"/ip6/::/tcp/4001”,
"/ip4/0.0.0.0/udp/4001/quic-v1”,
"/ip4/0.0.0.0/udp/4001/quic-v1/webtransport”,
"/ip6/::/udp/4001/quic-v1”,
"/ip6/::/udp/4001/quic-v1/webtransport”
"AutoNAT": {},
"Bootstrap": [
"/dnsaddr/bootstrap.libp2p.io/p2p/QmbLHAnMoJPWSCR5Zhtx6BHJX9KiKNN6tpvbUcqanj75Nb”,
"/dnsaddr/bootstrap.libp2p.io/p2p/QmcZf59bWwK5XFi76CZX8cbJ4BhTzzA3gU1ZjYZcYW3dwt”,
"/ip4/104.131.131.82/tcp/4001/p2p/QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ”,
"/ip4/104.131.131.82/udp/4001/quic-v1/p2p/QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ”,
"/dnsaddr/bootstrap.libp2p.io/p2p/QmNnooDu7bfjPFoTZYxMNLWUQJyrVwtbZg5gBMjTezGAJN”,
"/dnsaddr/bootstrap.libp2p.io/p2p/QmQCU2EcMqAqQPR2i9bChDtGNJchTbq5TbXJJ16u19uLTa”
"DNS": {
"Resolvers": {}
"Datastore": {
"BloomFilterSize": 0,
"GCPeriod": “1h”,
"HashOnRead": false,
"Spec": {
"mounts": [
"child": {
"path": “blocks”,
"shardFunc": "/repo/flatfs/shard/v1/next-to-last/2”,
"sync": true,
"type": “flatfs”
"mountpoint": "/blocks”,
"prefix": “flatfs.datastore”,
"type": “measure”
"child": {
"compression": “none”,
"path": “datastore”,
"type": “levelds”
"mountpoint": “/“,
"prefix": “leveldb.datastore”,
"type": “measure”
"type": “mount”
"StorageGCWatermark": 90,
"StorageMax": “10GB”
"Discovery": {
"MDNS": {
"Enabled": true
"Experimental": {
"FilestoreEnabled": false,
"OptimisticProvide": false,
"P2pHttpProxy": false,
"StrategicProviding": false,
"UrlstoreEnabled": false
"Gateway": {
"APICommands": [],
"DeserializedResponses": null,
"DisableHTMLErrors": null,
"ExposeRoutingAPI": null,
"HTTPHeaders": {},
"NoDNSLink": false,
"NoFetch": false,
"PathPrefixes": [],
"PublicGateways": null,
"RootRedirect": “”
"Identity": {
"PeerID": “12D3KooWM8MGxAXxbGSbui7KXCshKA9qzja4USoD8AXdMW9snAGz”
"Internal": {},
"Ipns": {
"RecordLifetime": “”,
"RepublishPeriod": “”,
"ResolveCacheSize": 128
"Migration": {
"DownloadSources": [],
"Keep": “”
"Mounts": {
"FuseAllowOther": false,
"IPFS": "/ipfs”,
"IPNS": “/ipns”
"Peering": {
"Peers": null
"Pinning": {
"RemoteServices": {}
"Plugins": {
"Plugins": null
"Provider": {
"Strategy": “”
"Pubsub": {
"DisableSigning": false,
"Router": “”
"Reprovider": {},
"Routing": {
"Methods": null,
"Routers": null
"Swarm": {
"AddrFilters": null,
"ConnMgr": {},
"DisableNatPortMap": false,
"RelayClient": {},
"RelayService": {},
"ResourceMgr": {},
"Transports": {
"Multiplexers": {},
"Network": {},
"Security": {}
Now I got IPFS Desktop running on my local desktop and I want it to connect to an IPFS cluster running on google cloud. Do I still need to update address.api. I will run IPFS Desktop on my laptop only. I’m not sure what to change to point to the nodes running on a private cluster.
Even if I change the bootstrap address to only the one of my cluster, something like:
"Bootstrap": [
"/ip4/x.x.x.x/tcp/8085/p2p/QmVKuLVFyBX2ZSyB2w7YLpH4AM7YCdaqdNRjwZa9cR335M”
I still have IPFS Desktop discover global peers. I see almost 300 peers and files from a public cluster, instead of just my cluster that is only 9 nodes.
