Creating an ephemeral IPFS node with consistent keypair
From @harlantwood on Sat Nov 28 2015 03:15:00 GMT+0000 (UTC)
I plan to set up an IPFS node on Circle CI which has a consistent keypair, so it can sign IPNS records. The node will be ephemeral; created fresh on each build. My plan so far is to use GitHub - ipfs/js-ipfsd-ctl: Control an IPFS daemon (go-ipfs or js-ipfs) using JavaScript! to spin up a node, and set the public/private key from environment variables stored within Circle CI.
Sound good? Better ways to do any of this?
Copied from original issue: Creating an ephemeral IPFS node with consistent keypair · Issue #79 · ipfs-inactive/faq · GitHub
From @harlantwood on Sat Nov 28 2015 05:34:59 GMT+0000 (UTC)
In IRC, @lgierth said:
that sounds good to me
From @jbenet on Tue Dec 01 2015 15:14:50 GMT+0000 (UTC)
SGTM too
On Fri, Nov 27, 2015 at 9:35 PM Harlan T Wood notifications@github.com
wrote:
Reply to this email directly or view it on GitHub
Creating an ephemeral IPFS node with consistent keypair · Issue #79 · ipfs-inactive/faq · GitHub.
