Hi all,
I have a small project in which i get some liberty to experiment so I’m trying out an IPFS (private with swarm key) network as a backend.
I want to store files, but these files exist of blocks that repeat between files (<4k per block)
I was wondering if it would be possible/wise to split these files into these logical sections, store each section separately, then manually link these as a file. So that when I want to retrieve a file by its hash, i automagically get all the blocks in the right order, but when adding a file, I split it into the logical sections myself, then add those as blocks manually.
Your advise is appreciated
