Deima – Decentralised Image Hosting Using IPFS
I have written a quick proof-of-concept decentralised image host(ing solution) using js-ipfs:
https://boramalper.github.io/deima/
It is, as you might guess, not as friction-free as one would expect from other traditional services (e.g. Imgur) but I found it surprisingly easy to develop and to use it. Check the repo I’ve linked and give deima a try yourself! https://boramalper.github.io/deima/image/#QmW8j8Dhhh3mhedGi2KsBNUXF7kkQoKMW5PQmm6onUigA2
It’s getting quite late here (2:43 AM) but I would happily respond to your questions & comments in the morning.
Bora
Thanks, I am interested in examining your Deima image hosting concept, but none of the links you posted are working at the moment, even the github.
Based on the archived github repo (https://github.com/boramalper/deima), it says:
ABANDONED: doesn’t work as intended; retained for historical reasons.
