Error for:Public Gateway Is Not Supported Anymore
When I visit my picture address( https://ipfs.infura.io/ipfs/QmQ6aMF4qQSciJQYr3PPnLScYY3LU8oLQ4TUvnV2ytdS12 )When I reported this error, how can I solve it
Hey Jacky,
Infura recently stopped operating their public IPFS Gateway https://blog.infura.io/post/introducing-ipfs-dedicated-gateways#deprecation-of-the-public-api-and-gateway
I would recommend using any of the other public IPFS gateways which you can find on Public Gateway Checker | IPFS
But a timeout prompt appears when using other gateways(504 Gateway Time-out)
In that case, it could be due to a number of reasons.
Are you pinning the CID anywhere?
Check out the following blog post to learn how to debug these errors with timeouts through gateways A Practical Explainer for IPFS Gateways - Part 2 | IPFS Blog & News
If your data is hosted with Infura it could be worth asking them. FWIW I see that CID in the DHT but can’t seem to retrieve it either.
