I am not able to get files from ipfs. Can it be that ipfs.infura.io is down?
ipfs.infura.io is a public gateway…
At the moment, it’s listed as up and running with a 0.89s response time per the only list I know of showing public gateways:
https://ipfs.github.io/public-gateway-checker/
If infura isn’t responding well for you, you could try any of the other public gateways… or the CID is located on a node that is down or undialable.
