Ipfs.io and filecoin.io,get 502?
what happend, anything update?
I can’t access it too
You can always use other gateways or the IPFS daemon to access the main IPNS:
https://siderus.io/ipns/filecoin.io/
https://siderus.io/ipns/ipfs.io/
:slight_smile:
What is the error that is blocking you from accessing it?
Where are you located? It could be that some ISP are blocking IPFS gateway for some reason ( Spain? Happened? don’t remember ).
The best/quickest solution would be to install IPFS locally and access those websites by going on your local gateway. For example, http://localhost:8080/ipns/ipfs.io/ will provide you the website hosted via IPNS.
now, It’s accessible. Thank you very much.
