I’m running an IPFS server on my Rasberry Pi. (more information on background in Feasibility for Self-Hosting Scientific Datasets?). I noticed that several days ago the service went offline.
First I checked: sudo systemctl status ipfs, which gives:
× ipfs.service - IPFS daemon
Loaded: loaded (/etc/systemd/system/ipfs.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2024-02-16 02:14:56 UTC; 5 days ago
Main PID: 967 (code=exited, status=2)
CPU: 2d 11h 28min 38.869s
Feb 16 02:14:40 mojo ipfs[967]: goroutine 119468909 [semacquire]:
Feb 16 02:14:40 mojo ipfs[967]: runtime.gopark(0x1a29ecc, 0x2942450, 0x12, 0x19, 0x4)
Feb 16 02:14:40 mojo ipfs[967]: runtime/proc.go:398 +0x104 fp=0x73835500 sp=0x738354ec pc=0x57900
Feb 16 02:14:40 mojo ipfs[967]: runtime.goparkunlock(...)
Feb 16 02:14:40 mojo ipfs[967]: runtime/proc.go:404
Feb 16 02:14:40 mojo ipfs[967]: runtime.semacquire1(0x4031f9c, 0x0, 0x1, 0x0, 0x12)
Feb 16 02:14:40 mojo ipfs[967]: runtime/sema.go:160 +0x270 fp=0x73835528 sp=0x73835500 pc=0x6c240
Feb 16 02:14:56 mojo systemd[1]: ipfs.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Feb 16 02:14:56 mojo systemd[1]: ipfs.service: Failed with result 'exit-code'.
Feb 16 02:14:56 mojo systemd[1]: ipfs.service: Consumed 2d 11h 28min 38.869s CPU time.
Looking at sudo journalctl -u ipfs.service
The head of the relevant log is:
-- Boot a862e97ecabd46cf9663871be3f18214 --
Feb 16 02:14:33 mojo ipfs[967]: runtime: out of memory: cannot allocate 4194304-byte block (3974135808 in use)
Feb 16 02:14:33 mojo ipfs[967]: fatal error: out of memory
Feb 16 02:14:33 mojo ipfs[967]: goroutine 119607122 [running]:
Feb 16 02:14:33 mojo ipfs[967]: runtime.throw({0x171682d, 0xd})
Feb 16 02:14:33 mojo ipfs[967]: runtime/panic.go:1077 +0x4c fp=0xd2d3e640 sp=0xd2d3e62c pc=0x541b4
Feb 16 02:14:33 mojo ipfs[967]: runtime.(*mcache).refill(0xf7b53088, 0x78)
Feb 16 02:14:33 mojo ipfs[967]: runtime/mcache.go:184 +0x244 fp=0xd2d3e670 sp=0xd2d3e640 pc=0x2944c
Feb 16 02:14:33 mojo ipfs[967]: runtime.(*mcache).nextFree(0xf7b53088, 0x78)
Feb 16 02:14:33 mojo ipfs[967]: runtime/malloc.go:929 +0x84 fp=0xd2d3e694 sp=0xd2d3e670 pc=0x1f388
Feb 16 02:14:33 mojo ipfs[967]: runtime.mallocgc(0x4800, 0x16038b0, 0x1)
Feb 16 02:14:33 mojo ipfs[967]: runtime/malloc.go:1116 +0x58c fp=0xd2d3e6cc sp=0xd2d3e694 pc=0x1fac8
Feb 16 02:14:33 mojo ipfs[967]: runtime.makechan(0x14738c0, 0x100)
and the tail is:
ipfs --version is ipfs version 0.26.0
IPFS config is:
"API": {
"HTTPHeaders": {
"POST"
"http://localhost:3000",
"https://webui.ipfs.io",
"http://127.0.0.1:5001"
"Addresses": {
"Announce": null,
"AppendAnnounce": [
"/ip4/172.100.113.212/tcp/4001",
"/ip4/172.100.113.212/udp/4001/quic",
"/ip4/172.100.113.212/udp/4001/quic-v1",
"/ip4/172.100.113.212/udp/4001/quic-v1/webtransport"
"NoAnnounce": null,
"Swarm": [
"/ip4/0.0.0.0/tcp/4001",
"/ip6/::/tcp/4001",
"/ip6/::/udp/4001/quic-v1",
"AutoNAT": {
"ServiceMode": "disabled"
"Bootstrap": [
"/ip4/104.131.131.82/udp/4001/quic-v1/p2p/QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ",
"/dnsaddr/bootstrap.libp2p.io/p2p/QmQCU2EcMqAqQPR2i9bChDtGNJchTbq5TbXJJ16u19uLTa"
"DNS": {
"Resolvers": {}
"Datastore": {
"BloomFilterSize": 0,
"GCPeriod": "1h",
"HashOnRead": false,
"Spec": {
"mounts": [
"child": {
"path": "blocks",
"sync": true,
"type": "flatfs"
"mountpoint": "/blocks",
"prefix": "flatfs.datastore",
"type": "measure"
"child": {
"compression": "none",
"path": "datastore",
"type": "levelds"
"mountpoint": "/",
"type": "measure"
"type": "mount"
"StorageGCWatermark": 90,
"StorageMax": "10GB"
"Discovery": {
"MDNS": {
"Enabled": true,
"Interval": 10
"Experimental": {
"FilestoreEnabled": false,
"GraphsyncEnabled": false,
"P2pHttpProxy": false,
"StrategicProviding": false,
"UrlstoreEnabled": false
"Gateway": {
"APICommands": [],
"HTTPHeaders": {},
"NoDNSLink": false,
"NoFetch": false,
"PathPrefixes": [],
"PublicGateways": null,
"RootRedirect": "",
"Writable": false
"Identity": {
"PeerID": "12D3KooWMJxwdSsxYwyb6KCqHNpBcE2oM9HWz6yNkRHiavgQLsbr"
"Internal": {},
"Ipns": {
"RecordLifetime": "",
"RepublishPeriod": "",
"ResolveCacheSize": 128
"Migration": {
"DownloadSources": [],
"Keep": ""
"Mounts": {
"FuseAllowOther": false,
"IPFS": "/ipfs",
"IPNS": "/ipns"
"Peering": {
"Peers": null
"Pinning": {
"RemoteServices": {}
"Plugins": {
"Plugins": null
"Provider": {
"Strategy": ""
"Pubsub": {
"DisableSigning": false,
"Router": ""
"Reprovider": {
"Interval": "0",
"Strategy": "all"
"Routing": {
"AcceleratedDHTClient": true,
"Type": "dhtclient"
"Swarm": {
"AddrFilters": null,
"ConnMgr": {
"GracePeriod": "1m0s",
"HighWater": 40,
"LowWater": 20,
"Type": "basic"
"DisableNatPortMap": false,
"RelayClient": {},
"RelayService": {},
"Transports": {
"Multiplexers": {},
"Network": {},
"Security": {}
OS Info:
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=22.04
DISTRIB_CODENAME=jammy
DISTRIB_DESCRIPTION="Ubuntu 22.04.3 LTS"
Is there anything obvious that I need to fix?
