root@a1-desktop:~# ipfs daemon
Initializing daemon…
go-ipfs version: 0.12.0
Repo version: 12
System version: amd64/linux
Golang version: go1.16.12
2022-04-19T12:26:24.138+0300 ERROR p2p-config config/config.go:113 tried to create a libp2p node with no Private Network Protector but usage of Private Networks is forced by the enviroment
2022-04-19T12:26:24.139+0300 ERROR cmd/ipfs ipfs/daemon.go:430 error from node construction: could not build arguments for function “github.com/ipfs/go-ipfs/core/node”.PeerWith.func1 (github.com/ipfs/go-ipfs@v0.12.0/core/node/peering.go:29): failed to build *peering.PeeringService: could not build arguments for function “github.com/ipfs/go-ipfs/core/node”.Peering (github.com/ipfs/go-ipfs@v0.12.0/core/node/peering.go:14): failed to build host.Host: received non-nil error from function “github.com/ipfs/go-ipfs/core/node/libp2p”.Host (github.com/ipfs/go-ipfs@v0.12.0/core/node/libp2p/host.go:40): privnet: private network was not configured but is enforced by the environment
Error: could not build arguments for function “github.com/ipfs/go-ipfs/core/node”.PeerWith.func1 (github.com/ipfs/go-ipfs@v0.12.0/core/node/peering.go:29): failed to build *peering.PeeringService: could not build arguments for function “github.com/ipfs/go-ipfs/core/node”.Peering (github.com/ipfs/go-ipfs@v0.12.0/core/node/peering.go:14): failed to build host.Host: received non-nil error from function “github.com/ipfs/go-ipfs/core/node/libp2p”.Host (github.com/ipfs/go-ipfs@v0.12.0/core/node/libp2p/host.go:40): privnet: private network was not configured but is enforced by the environment
I Hope someone can help…
