File argument 'path' is required for 'virtual file' using weird language to form HTTP
I appreciate that this issue has come up in a variety of contexts including:
Here, just about using curl properly.
This that is very close to my issue but basically resolves by saying yes a real path is expected.
Here, a daughter issue of the above requiring a real PATH (we’re so close).
Closest match but I can’t see the resulting HTTP request so I’m not sure what’s being formed and also I don’t think infura will let me use /files
I’m running into this issue presently, trying to form a POST to infura.io to add a file to IPFS using a language called Hoon which is used in a project called Urbit.
I’ve gotten pretty close, but no matter what I do, I can’t seem to get Abspath: /a/path.png to be recognized by the endpoint to allow the upload. Further, when I try to copy headers created by logging the raw output of curl and postman, I don’t even see the Abspath at all in what it produces.
Here’s some documentation of what I’ve tried so far and the results I get from each try..
Any help would be greatly appreciated.
EDIT: note that sometimes I posted to localhost:1090 where I had netcat listening to write to file to get my output so assume that I’m actually pointing at the right endpoint.
EDIT 2: I don’t even have a real filepath as I’m actually grabbing the raw data of a png from another web-generator of pngs to post to IPFS. The eventual goal would be generative creation of content to be posted to IPFS .
I don’t get what is your question ?
I mean, yes all of this is confusing, but I would blame the multipart/form-data specs for being confusing. :slight_smile:
(we could maybe make the docs and error message better ?)
I’ve just learnt about that language from you and have no idea how to use it, but you need to create a multipart/form-data with a path param in the form-data.
It seems in most like people try passing the path as a GET parameters while I belive it should be in form-data.
My question is what does the raw HTTP need to look like.
If I understand your answer correctly, I need to pass path, and I think that’s right, but somehow I’m doing it wrong and I can’t quite figure out how.
In this discussion I linked to, they show that parameter as Abspath:, which I have tried a few ways but not had success. Also I can’t see it in what I’ve recorded from Postman and curl when logging the results of what would have otherwise been a successful call to infura and neither of those actually show that ‘header’ where I think it would go, yet, as I say, they are otherwise successful.
Is Abspath wrong? Is it checked somehow for validity? What encoding does it expect?
edit:
It seems in most like people try passing the path as a GET parameters while I belive it should be in form-data .
This is I think where I’m having the issue - I’m trying to code it in there but I lack sufficient information about what that looks like at raw http level.
Abspath is used if you use the filestore.
By default if you add /tmp/example to IPFS, the blocks making /tmp/example are copied into ~/.ipfs/blocks/..., to do that the CLI reads /tmp/example and stream the bytes over the HTTP connection.
If you use the filestore, IPFS’s datastore store the path as well as offset and length kinda like this /tmp/example:123:20 (IPFS blocks are far bigger than 20 bytes, just this is an example).
Then if someone wants to download this file from you, your deamon open /tmp/example and read it from there, that avoid having too copy of /tmp/example stored on your machine.
This is useless if you doesn’t use filestore.
An example
Here some random golang code dealing with the form-data of IPFS add:
Ok - I’m not using filestore, I don’t think. Specifically, I don’t need the data to stay up to date against some purported local file.
Using my language, I’m generating this http:
POST / HTTP/1.1
Host: <infura endpoint>
Authorization: Basic <redacted>
Content-Length: 592717
Content-Type: multipart/form-data; boundary=----------------------------------0v2.umn44.gcqjl.9n01c.b9tek.f1na9
Content-Length: 596.290
------------------------------------0v2.umn44.gcqjl.9n01c.b9tek.f1na9
Content-Disposition: form-data; name=''; filename='2022.1.25..01.55.46-dalten-2022%2C01%2C26.png'
Content-Type: image/png
�PNG
<redacted for brevity>
------------------------------------0v2.umn44.gcqjl.9n01c.b9tek.f1na9--
and infura is responding:
'file argument \'path\' is required\0a'
(more verbosely here)
I get the same response back if I exclude Abspath. Also - like I said, I don’t see that in a simple curl or postman call that actually does work so idgi why my version isn’t working. I know this is hard without knowing the specifics of my language, too - thank you for helping me consider my issue.
As it turns out, the issue had something to do w/ encoding and not w/ that path at all. Not sure why it exhibited the way it did, but there we go.
Thank you for your assistance, board and @Jorropo .
EDIT: I am not specifying Abspath: My body looks something like this:
----------------------------a_separator
Content-Disposition: form-data; name="file"; filename="pxArt.png"
<file data>----------------------------a_separator--
Good :slight_smile:
I was not really sure why it was failing, happy to see you suceed.
