Hi IPFS,
I am trying to implement the dag-pb functionality in c++. I almost got it correct (by comparing the dag and mutihash resulted from adding a file), but I’m stuck in a problem.
I think normally the field order after serialization in protobuf is determined by the field number in a .proto file. And IPFS has PBNode defined as
message PBNode {
// refs to other objects
repeated PBLink Links = 2;
// opaque user data
optional bytes Data = 1;
So I expect after serialization a PBNode, the Links field should be after the Data field. And this is the behavior in my implementation. But ipfs block get <cid> | protoc --decode_raw shows the order is not in that order. The following is an example (excerpted).
2 {
1 {
2: "#\332r\216K~\024M\\\367\234\245\352\234\244\314\303&~\270m+\217Fh0\005D\254\313\322\350"
2: ""
3: 523
2 {
1 {
2: "\212.\371G\202\re\033Ko\240QR\035\371\264\363GZ\355\'l\306\031Q>\250\335\"\262-("
2: ""
3: 27
1 {
1: 2
3: 31763
4: 512
4: 512
4: 512
4: 512
4: 512
4: 512
So the Data = 1 filed comes after the Links = 2 field. I believe it is this inconsistency that makes my multihash differs from go-ipfs’ multihash. My question is: is this “mis-ordering” intended by IPFS? How should I make my code consistent with IPFS?
I’m new to protobuf. I tried to google, but didn’t find a solution to change the order. Any help will be appreciated!
