Hi. I’m new in IPFS World.
I think IPFS is very interesting and want to use it.
My system is solaris 11.3, but there is no binary for the OS.
I tried to build the source(go-ipfs) according to the guide for openBSD(https://github.com/ipfs/go-ipfs/blob/master/docs/openbsd.md),
but failed …
The below is the error messages
$ go install -v -tags nofuse ./cmd/ipfs
gx/ipfs/QmeoWapXvjjwRqLczX6ufvPTk6w8xzso35AoYNa8PRrDKs/go-reuseport
*gx/ipfs/QmeoWapXvjjwRqLczX6ufvPTk6w8xzso35AoYNa8PRrDKs/go-reuseport
…/…/…/gx/ipfs/QmeoWapXvjjwRqLczX6ufvPTk6w8xzso35AoYNa8PRrDKs/go-reuseport/interface.go:33:9: undefined: available
…/…/…/gx/ipfs/QmeoWapXvjjwRqLczX6ufvPTk6w8xzso35AoYNa8PRrDKs/go-reuseport/interface.go:50:6: undefined: available
…/…/…/gx/ipfs/QmeoWapXvjjwRqLczX6ufvPTk6w8xzso35AoYNa8PRrDKs/go-reuseport/interface.go:54:9: undefined: listenStream
…/…/…/gx/ipfs/QmeoWapXvjjwRqLczX6ufvPTk6w8xzso35AoYNa8PRrDKs/go-reuseport/interface.go:61:6: undefined: available
…/…/…/gx/ipfs/QmeoWapXvjjwRqLczX6ufvPTk6w8xzso35AoYNa8PRrDKs/go-reuseport/interface.go:65:9: undefined: listenPacket
…/…/…/gx/ipfs/QmeoWapXvjjwRqLczX6ufvPTk6w8xzso35AoYNa8PRrDKs/go-reuseport/interface.go:72:6: undefined: available
…/…/…/gx/ipfs/QmeoWapXvjjwRqLczX6ufvPTk6w8xzso35AoYNa8PRrDKs/go-reuseport/interface.go:102:6: undefined: available
…/…/…/gx/ipfs/QmeoWapXvjjwRqLczX6ufvPTk6w8xzso35AoYNa8PRrDKs/go-reuseport/interface.go:106:9: undefined: dial
gx/ipfs/Qmb3GBFCHMuzmi9EpH3pxpYBiviyc3tEPyDQHxZJQJSxj9/badger/y
*gx/ipfs/Qmb3GBFCHMuzmi9EpH3pxpYBiviyc3tEPyDQHxZJQJSxj9/badger/y
…/…/…/gx/ipfs/Qmb3GBFCHMuzmi9EpH3pxpYBiviyc3tEPyDQHxZJQJSxj9/badger/y/mmap_unix.go:57:30: undefined: syscall.SYS_MADVISE
I haven’t done this before on OpenBSD, but from my interpretation of the instructions you’re not supposed to manually run go install -tags nofuse ./cmd/ipfs. Rather, the commands below eventually do it for you.
$ go get -v -u -d github.com/ipfs/go-ipfs
$ cd $GOPATH/src/github.com/ipfs/go-ipfs
$ gmake install_unsupported
Assuming you have already successfully run the commands from earlier on in the document to prepare your environment, do the commands copy/pasted above give you any errors?
Thanks leerspace
In fact, I did follow the guide, and had the same result with the above.
“go get -v -u -d github.com/ipfs/go-ipfs”
“cd $GOPATH/src/github.com/ipfs/go-ipfs”
“gmake install_unsupported”
Then, I had the failure for “gmake install_unsupported”.
I just did run “go install -v -tags nofuse ./cmd/ipfs” to find the reason why the go compiler couldn’t find the symbol in the same package: the symbols, ‘available’, ‘listenStream’ and ‘listenPacket’ in the file, interface.go are definded in the other go file in the same package.
The below is the part of the result from “gmake install_unsupported”
[done] [install] 1ms QmYKNMEUK7nCVAefgXF1LVtZEZg3uRmBqiae4FJRXDNAyJ go-path
[done] [install] 0s QmSaz8Qg77gGqvDvLKeSAY7ivDEnramSWF6T7TcRwFpHtP go-unixfs
installing go-ipfs
gx/ipfs/QmVGjyM9i2msKvLXwh9VosCTgP4mL91kC7hDmqnwTTx6Hu/sys/cpu
gx/ipfs/QmW7VUmSvhvSGbYbdsh7uRjhGmsYkc9fL8aJ5CorxxrU5N/go-crypto/blake2s
gx/ipfs/QmW7VUmSvhvSGbYbdsh7uRjhGmsYkc9fL8aJ5CorxxrU5N/go-crypto/sha3
gx/ipfs/QmWFAMPqsEyUX7gDUsRVmMWz59FxSpJ1b2v6bJ1yYzo7jY/go-base58-fast/base58
gx/ipfs/QmXTpwq2AkzQsPjKqFQDNY2bMdsAT53hUBETeyj8QRHTZU/sha256-simd
gx/ipfs/QmZp3eKdYQHHAneECmeK6HhiMwTPufmjC8DuuaGKv3unvx/blake2b-simd
gx/ipfs/QmZtJMfZZvoD3EKpQaf8xsFi83HMtX5acQekY8exMbcWEi/keccakpg
gx/ipfs/QmfJHywXQu98UeZtGJBQrPAR6AtmDjjbe3qjTo9piXHPnx/murmur3
gx/ipfs/QmPnFwZ2JXKnXgMw8CdBPxn7FWh6LLdjUjxV1fKHuJnkr8/go-multihash
gx/ipfs/QmfVj3x4D6Jkq9SEoi5n2NmoUomLwoeiwnYz2KQa15wRw6/base32
gx/ipfs/QmexBtiTTEwwn42Yi6ouKt6VqzpA6wjJgiW1oh9VfaRrup/go-multibase
gx/ipfs/QmYVNvtQkeZ6AKSwDrjQTs432QtL6umrrK41EBq3cu7iSP/go-cid
gx/ipfs/QmQwgv79RHrRnoXmhnpC1BPtY55HHeneGMpPwmmBU1fUAG/go-verifcid
gx/ipfs/QmPdKqUcHGFdeSpvjVoaTRPPstGif9GBZb5Q56RVw9o69A/go-ipfs-util
gx/ipfs/QmVzK524a2VWLqyvtBeiHKsUAWYgeAk4DBeZoY7vpNPNRx/go-block-format
gx/ipfs/QmVYxfoJQiZijTgPNHCHgHELvQpbsJNTg6Crmc3dQkj3yy/golang-lru/simplelru
gx/ipfs/QmWaLViWQF8jgyoLLqqcSrnp6dJpHESiJfzor1vrfDyTZf/bbloom
gx/ipfs/QmQvJiADDe7JR4m968MwXobTCCzUqQkP87aRHe29MEBGHV/go-logging
gx/ipfs/QmVGjyM9i2msKvLXwh9VosCTgP4mL91kC7hDmqnwTTx6Hu/sys/unix
gx/ipfs/QmWVGFCGGTAGrT3adV261k1h6nntcyDhGVszGV2i2pzwPe/go-isatty
gx/ipfs/QmTsHcKgTQ4VeYZd8eKYpTXeLW7KNwkRD9wjnrwsV2sToq/go-colorable
gx/ipfs/QmWLWmRVSiagqP15jczsGME1qpob6HDbtbHAY2he9W5iUo/opentracing-go/log
gx/ipfs/QmWLWmRVSiagqP15jczsGME1qpob6HDbtbHAY2he9W5iUo/opentracing-go/ext
gx/ipfs/QmZ4Qi3GaRbjcx28Sme5eMH7RQjGkt8wHxt2a65oLaeFEV/gogo-protobuf/proto
gx/ipfs/QmcVVHfdyv15GVPk7NrxdWjh2hLVccXnoD8j2tyQShiXJb/go-log/tracer/wire
gx/ipfs/QmcVVHfdyv15GVPk7NrxdWjh2hLVccXnoD8j2tyQShiXJb/go-log/writer
gx/ipfs/QmcBWojPoNh4qm7zvv4qiepvCnnc7ALS9qcp7TNwwxT1gT/go.uuid
gx/ipfs/QmSF8fPo3jgVBAy8fpdjjYqgG87dkJgUprRBHRd2tmfgpP/goprocess
gx/ipfs/QmeiCcJfDW1GJnWUArudsv5rQsihpi4oyddPhdqo3CfX6i/go-datastore/query
gx/ipfs/Qmd8UZEDddMaCnQ1G5eSrUhN3coX19V7SyXNQGWnAvUsnT/go-ipfs-ds-help
gx/ipfs/QmeiCcJfDW1GJnWUArudsv5rQsihpi4oyddPhdqo3CfX6i/go-datastore/keytransform
gx/ipfs/QmeiCcJfDW1GJnWUArudsv5rQsihpi4oyddPhdqo3CfX6i/go-datastore/namespace
gx/ipfs/QmekzFM3hPZjTjUFGTABdQkEnQ3PTiMstY198PwSFr5w1Q/go-metrics-interface
gx/ipfs/QmadMhXJLHMFjpRmh85XjpmVDkEtQpNYEZNRpWRvYVLrvb/go-ipfs-blockstore
gx/ipfs/Qmc2faLf7URkHpsbfYM4EMbr8iSAcGAe8VPgVi64HVnwji/go-ipfs-exchange-interface
gx/ipfs/QmNqRBAhovtf4jVd5cF7YvHaFSsQHHZBaUFwGQWPM2CV7R/go-blockservice
gx/ipfs/QmRy4Qk9hbgFX9NGJRm8rBThrA8PZhNCitMgeRYyZ67s59/go-merkledag/pb
gx/ipfs/QmZtNq8dArGfnpCZfx2pUNY7UcjGhVp5qqwQ4hH6mpTMRQ/go-ipld-format
gx/ipfs/QmcRKRQjNc2JZPHApR32fbkZVd6WXG2Ch9Kcy7sPxuAJgd/cbor/go
gx/ipfs/QmWrbExtUaQQHjJ8FVVDAWj5o1MRAELDUV3VmoQsZHHb6L/go-ipld-cbor
gx/ipfs/QmS6mo1dPpHdYsVkm27BRZDLxpKBCiJKUH8fHX15XFfMez/go-ipfs-exchange-offline
gx/ipfs/QmYKNMEUK7nCVAefgXF1LVtZEZg3uRmBqiae4FJRXDNAyJ/go-path
gx/ipfs/QmeiCcJfDW1GJnWUArudsv5rQsihpi4oyddPhdqo3CfX6i/go-datastore/sync
github.com/ipfs/go-ipfs/dagutils
github.com/ipfs/go-ipfs/pin/internal/pb
gx/ipfs/QmPJUtEJsm5YLUWhF6imvyCH8KZXRJa9Wup7FDMwTy5Ufz/backoff
gx/ipfs/QmZ383TySJVeZWzGnWui6pRcKyYZk9VkKTuW7tmKRWk5au/go-libp2p-routing/options
gx/ipfs/QmYmsdtJ3HsodkePE3eU3TsCaP2YvPZJ4LoXnNkDE5Tpt7/go-multiaddr
gx/ipfs/QmQscWDtDBDsWAM58aY6gU2KtxyFFmvvZgdfJExYPLgtXA/mafmt
gx/ipfs/QmV6FjemM1K8oXjrvuq3wuVWWoU2TLDPmNnKrxHzY3v6Ai/go-multiaddr-net
gx/ipfs/QmZR2XWVVBCtbgBWnQhWk2xcQfaR3W8faQPriAiaaj7rsr/go-libp2p-peerstore/addr
gx/ipfs/QmQ51pHe6u7CWodkUGDLqaCEMchkbMt7VEZnECF5mp6tVb/ed25519/edwards25519
gx/ipfs/QmQ51pHe6u7CWodkUGDLqaCEMchkbMt7VEZnECF5mp6tVb/ed25519/extra25519
gx/ipfs/QmWq5PJgAQKDWQerAijYUVKW8mN5MDatK5j7VMp8rizKQd/btcec
gx/ipfs/Qme1knMqwt1hKZbc1BmQFmnm9f36nyQGwXxPGVpVJ9rMK5/go-libp2p-crypto/pb
gx/ipfs/QmdVrMn1LhB4ybb8hMVaMLXnA8XRSewMnK6YqXKXoTcRvN/go-libp2p-peer
github.com/ipfs/go-ipfs/exchange/reprovide
github.com/ipfs/go-ipfs/filestore/pb
gx/ipfs/QmSHjPDw8yNgLZ7cBfX7w3Smn7PHwYhNEpd4LHQQxUg35L/go-ipfs-posinfo
gx/ipfs/QmZHU2gx42NPTYXzw6pJkuX6xCE7bKECp6e8QcPdoLx8sx/protobuf/proto
github.com/ipfs/go-ipfs/fuse/mount
gx/ipfs/QmSaz8Qg77gGqvDvLKeSAY7ivDEnramSWF6T7TcRwFpHtP/go-unixfs/pb
gx/ipfs/QmTbBs3Y3u5F69XNJzdnnc6SP5GKgcXxCDzx6w8m6piVRT/go-bitfield
gx/ipfs/QmSaz8Qg77gGqvDvLKeSAY7ivDEnramSWF6T7TcRwFpHtP/go-unixfs/hamt
gx/ipfs/QmSaz8Qg77gGqvDvLKeSAY7ivDEnramSWF6T7TcRwFpHtP/go-unixfs/io
gx/ipfs/QmWBug6eBS7AxRdCDVuSY5CnSit7cS2XnPFYJWqWDumhCG/go-msgio/mpool
gx/ipfs/QmZooytqEoUwQjv7KzH4d3xyJnyvD3AWJaCDMYt5pbCtua/chunker
gx/ipfs/QmVDjhUMtkRskBFAVNwyXuLSKbeAya7JKPnzAxMKDaK4x4/go-ipfs-chunker
gx/ipfs/QmdE4gMduCKCGAcczM2F5ioYDfdeKuPix138wrES1YSr7f/go-ipfs-cmdkit/files
gx/ipfs/QmSaz8Qg77gGqvDvLKeSAY7ivDEnramSWF6T7TcRwFpHtP/go-unixfs/importer/helpers
gx/ipfs/QmSaz8Qg77gGqvDvLKeSAY7ivDEnramSWF6T7TcRwFpHtP/go-unixfs/importer/trickle
gx/ipfs/QmSaz8Qg77gGqvDvLKeSAY7ivDEnramSWF6T7TcRwFpHtP/go-unixfs/mod
github.com/ipfs/go-ipfs/mfs
github.com/ipfs/go-ipfs/namesys/opts
gx/ipfs/QmY9JXR3FupnYAYJWK9aMr9bCpqWKcToQ1tz8DVGTrHpHw/go-stream-muxer
gx/ipfs/QmZNkThpqfVXs9GNbexPrfBbXSLNYeKrE7jwFM2oqHbyqN/go-libp2p-protocol
gx/ipfs/QmPjvxTpVH8qJyQDnxnsxF9kv9jezKD1kozz1hs3fCGsNh/go-libp2p-net
gx/ipfs/QmQNQhNmY4STU1MURjH9vYEMpx2ncMS4gbwxXWtrEjzVAq/go-todocounter
gx/ipfs/QmRPkGkHLB72caXgdDYnoaWigXNWx95BcYDKV1n3KTEpaG/go-libp2p-loggables
gx/ipfs/QmSF8fPo3jgVBAy8fpdjjYqgG87dkJgUprRBHRd2tmfgpP/goprocess/context
gx/ipfs/QmSF8fPo3jgVBAy8fpdjjYqgG87dkJgUprRBHRd2tmfgpP/goprocess/periodic
gx/ipfs/QmTKsRYeY4simJyf37K93juSq75Lo8MVCDJ7owjmf46u8W/go-context/io
gx/ipfs/QmVsp2KdPYE6M8ryzCk5KHLo3zprcY5hBDaYx6uPCFUdxA/go-libp2p-record/pb
gx/ipfs/QmTktQYCKzQjhxF6dk5xJPRuhHn3JBiKGvMLoiDy1mYmxC/go-libp2p-kad-dht/opts
gx/ipfs/QmTktQYCKzQjhxF6dk5xJPRuhHn3JBiKGvMLoiDy1mYmxC/go-libp2p-kad-dht/pb
gx/ipfs/QmeiCcJfDW1GJnWUArudsv5rQsihpi4oyddPhdqo3CfX6i/go-datastore/autobatch
gx/ipfs/QmTktQYCKzQjhxF6dk5xJPRuhHn3JBiKGvMLoiDy1mYmxC/go-libp2p-kad-dht/providers
gx/ipfs/QmZ383TySJVeZWzGnWui6pRcKyYZk9VkKTuW7tmKRWk5au/go-libp2p-routing/notifications
gx/ipfs/QmZ4Qi3GaRbjcx28Sme5eMH7RQjGkt8wHxt2a65oLaeFEV/gogo-protobuf/io
gx/ipfs/QmUusaX99BZoELh7dmPgirqRQ1FAmMnmnBn3oiqDFGBUSc/go-keyspace
gx/ipfs/QmZR2XWVVBCtbgBWnQhWk2xcQfaR3W8faQPriAiaaj7rsr/go-libp2p-peerstore/queue
gx/ipfs/QmXuucFcuvAWYAJfhHV2h4BYreHEAsLSsiquosiXeuduTN/go-libp2p-interface-connmgr
gx/ipfs/QmbXRda5H2K3MSQyWWxTMtd8DWuguEBUCe6hpxfXVpFUGj/go-multistream
gx/ipfs/QmcrrEpx3VMUbrbgVroH3YiYyUS5c4YAykzyPJWKspUYLa/go-semver/semver
gx/ipfs/Qmb8T6YBBsjYsVGfrihQLfCJveczZnneSBqBKkYEBWDjge/go-libp2p-host
gx/ipfs/QmdVrMn1LhB4ybb8hMVaMLXnA8XRSewMnK6YqXKXoTcRvN/go-libp2p-peer/peerset
gx/ipfs/QmesQqwonP618R7cJZoFfA4ioYhhMKnDmtUxcAvvxEEGnw/go-libp2p-kbucket/keyspace
gx/ipfs/QmYnf27kzqR2cxt6LFZdrAFJuQd6785fTkBvMuEj9EeRxM/proquint
gx/ipfs/QmZmmuAXgX73UQmX1jRKjTGmjzq24Jinqkq8vzkBtno4uX/go-is-domain
gx/ipfs/Qmdue1XShFNi3mpizGx9NR9hyNEj6U2wEW93yGhKqKCFGN/go-ipns/pb
github.com/ipfs/go-ipfs/keystore
github.com/ipfs/go-ipfs/namesys/republisher
github.com/ipfs/go-ipfs/p2p
github.com/ipfs/go-ipfs/Godeps/_workspace/src/github.com/mitchellh/go-homedir
gx/ipfs/QmW5LxJm2Yo3S7uVsfLM7NsJn2QnKbvZD7uYsZVYR7YViE/go-libp2p-transport
gx/ipfs/QmSW4uNHbvQia8iZDXzbwjiyHQtnyo9aFqfQAMasj3TJ6Y/go-maddr-filter
gx/ipfs/QmW7Ump7YyBMr712Ta3iEVh3ZYcfVvJaPryfbCnyE826b4/go-libp2p-interface-pnet
gx/ipfs/QmWHgLqrghM9zw77nF6gdvT9ExQ2RB9pLxkd8sDHZf1rWb/go-temp-err-catcher
gx/ipfs/QmYMGCwtKbLXfh2MUTbLoP66N9Y24DSg8PFJRG21eE2qwv/go-conn-security
gx/ipfs/Qma7AuxEA7dd1wAy95hTxXgxy4q7mU4Pyd1x4PRAzGP1fs/go-libp2p-transport-upgrader
gx/ipfs/QmcQ56iqKP8ZRhRGLe5EReJVvrJZDaGzkuatrPv4Z1B6cG/go-libp2p-circuit/pb
gx/ipfs/Qme4QgoVPyQqxVc4G1c2L2wc9TDa6o294rtspGMnBNRujm/go-ipfs-addr
gx/ipfs/QmfXU2MhWoegxHoeMd3A2ytL2P6CY4FfqGWc23LTNWBwZt/go-multiaddr-dns
github.com/ipfs/go-ipfs/repo/config
github.com/ipfs/go-ipfs/thirdparty/math2
github.com/ipfs/go-ipfs/thirdparty/verifbs
gx/ipfs/Qmbg4PQLEvf2XW8vrai9STFDerV7kttkfKcVdkoRf9Z7Xu/go-errwrap
gx/ipfs/QmfGQp6VVqdPCDyzEM6EGwMY74YPabTSEoQWHUxZuCSWj3/go-multierror
gx/ipfs/QmQpvpeXa8rBfDmt3bdh2ckw2867vsYN1ozf79X7U5rij9/go-libp2p-routing-helpers
gx/ipfs/QmW7VUmSvhvSGbYbdsh7uRjhGmsYkc9fL8aJ5CorxxrU5N/go-crypto/salsa20/salsa
gx/ipfs/QmNi5J1mEQKAKWbPRBEMKKYVNok9EN4MsGM4YUqPvraPEX/go-crypto-dav/salsa20
gx/ipfs/QmRDePEiL4Yupq5EkcK3L3ko3iMgYaqUdLu7xc1kqs7dnV/go-multicodec
gx/ipfs/QmRDePEiL4Yupq5EkcK3L3ko3iMgYaqUdLu7xc1kqs7dnV/go-multicodec/base
gx/ipfs/QmRDePEiL4Yupq5EkcK3L3ko3iMgYaqUdLu7xc1kqs7dnV/go-multicodec/base/b64
gx/ipfs/QmRDePEiL4Yupq5EkcK3L3ko3iMgYaqUdLu7xc1kqs7dnV/go-multicodec/base/bin
gx/ipfs/QmRDePEiL4Yupq5EkcK3L3ko3iMgYaqUdLu7xc1kqs7dnV/go-multicodec/base/hex
gx/ipfs/QmRDePEiL4Yupq5EkcK3L3ko3iMgYaqUdLu7xc1kqs7dnV/go-multicodec/cbor
gx/ipfs/QmRDePEiL4Yupq5EkcK3L3ko3iMgYaqUdLu7xc1kqs7dnV/go-multicodec/json
gx/ipfs/QmRDePEiL4Yupq5EkcK3L3ko3iMgYaqUdLu7xc1kqs7dnV/go-multicodec/mux
gx/ipfs/QmRDePEiL4Yupq5EkcK3L3ko3iMgYaqUdLu7xc1kqs7dnV/go-multicodec/base/mux
gx/ipfs/QmRGvSwDpN4eunxgDNfmQhayZ6Z9F5a2v31V2D7y77osLg/go-libp2p-pnet
gx/ipfs/QmXScvRbYh9X9okLuX9YMnz1HR4WgRTU2hocjBs15nmCNG/go-libp2p-floodsub/pb
gx/ipfs/QmYftoT56eEfUBTD3erR6heXuPSUhGRezSmhSU8LeczP8b/timecache
gx/ipfs/QmS3QZaaGMLwYQD1cWaGnM4san4zzT7z31tmhuXJMZ91dh/go-libp2p-pubsub-router
gx/ipfs/QmRJVNatYJwTAHgdSM1Xef9QVQ1Ch3XHdmcrykjP5Y4soL/go-ipfs-delay
gx/ipfs/QmRMGdC6HKdLsPDABL9aXPDidrpmEHzJqFWSvshkbn9Hj8/go-ipfs-flags
gx/ipfs/QmSLYFS88MpPsszqWdhGSxvHyoTnmaU4A74SD6KGib6Z3m/go-bitswap/message/pb
gx/ipfs/QmSLYFS88MpPsszqWdhGSxvHyoTnmaU4A74SD6KGib6Z3m/go-bitswap/wantlist
gx/ipfs/QmZUbTDJ39JpvtFCSubiWeUTQRvMA1tVE5RZCJrY4oeAsC/go-ipfs-pq
gx/ipfs/QmSLYFS88MpPsszqWdhGSxvHyoTnmaU4A74SD6KGib6Z3m/go-bitswap/decision
gx/ipfs/QmSLYFS88MpPsszqWdhGSxvHyoTnmaU4A74SD6KGib6Z3m/go-bitswap/network
gx/ipfs/QmdbxjQWogRCHRaxhhGnYdT1oQJzL9GdqSKzCdqWr85AP2/pubsub
gx/ipfs/QmSLYFS88MpPsszqWdhGSxvHyoTnmaU4A74SD6KGib6Z3m/go-bitswap/notifications
gx/ipfs/QmRvYNctevGUW52urgmoFZscT6buMKqhHezLUS64WepGWn/go-net/html/atom
gx/ipfs/QmVcxhXDbXjNoAdmYBWbY1eU67kQ8eZUHjG4mAYZUtZZu3/go-text/encoding/internal/identifier
gx/ipfs/QmVcxhXDbXjNoAdmYBWbY1eU67kQ8eZUHjG4mAYZUtZZu3/go-text/transform
gx/ipfs/QmVcxhXDbXjNoAdmYBWbY1eU67kQ8eZUHjG4mAYZUtZZu3/go-text/encoding/charmap
gx/ipfs/QmVcxhXDbXjNoAdmYBWbY1eU67kQ8eZUHjG4mAYZUtZZu3/go-text/encoding/japanese
gx/ipfs/QmVcxhXDbXjNoAdmYBWbY1eU67kQ8eZUHjG4mAYZUtZZu3/go-text/encoding/korean
gx/ipfs/QmVcxhXDbXjNoAdmYBWbY1eU67kQ8eZUHjG4mAYZUtZZu3/go-text/encoding/simplifiedchinese
gx/ipfs/QmVcxhXDbXjNoAdmYBWbY1eU67kQ8eZUHjG4mAYZUtZZu3/go-text/encoding/traditionalchinese
gx/ipfs/QmVcxhXDbXjNoAdmYBWbY1eU67kQ8eZUHjG4mAYZUtZZu3/go-text/internal/utf8internal
gx/ipfs/QmVcxhXDbXjNoAdmYBWbY1eU67kQ8eZUHjG4mAYZUtZZu3/go-text/runes
gx/ipfs/QmVcxhXDbXjNoAdmYBWbY1eU67kQ8eZUHjG4mAYZUtZZu3/go-text/encoding/unicode
gx/ipfs/QmVcxhXDbXjNoAdmYBWbY1eU67kQ8eZUHjG4mAYZUtZZu3/go-text/internal/tag
gx/ipfs/QmVcxhXDbXjNoAdmYBWbY1eU67kQ8eZUHjG4mAYZUtZZu3/go-text/internal/language
gx/ipfs/QmVcxhXDbXjNoAdmYBWbY1eU67kQ8eZUHjG4mAYZUtZZu3/go-text/internal/language/compact
gx/ipfs/QmVcxhXDbXjNoAdmYBWbY1eU67kQ8eZUHjG4mAYZUtZZu3/go-text/language
gx/ipfs/QmVcxhXDbXjNoAdmYBWbY1eU67kQ8eZUHjG4mAYZUtZZu3/go-text/encoding/htmlindex
gx/ipfs/QmRvYNctevGUW52urgmoFZscT6buMKqhHezLUS64WepGWn/go-net/html/charset
gx/ipfs/QmVwfv63beSAAirq3tiLY6fkNqvjThLnCofL7363YkaScy/goupnp/httpu
gx/ipfs/QmVwfv63beSAAirq3tiLY6fkNqvjThLnCofL7363YkaScy/goupnp/scpd
gx/ipfs/QmVwfv63beSAAirq3tiLY6fkNqvjThLnCofL7363YkaScy/goupnp/soap
gx/ipfs/QmVwfv63beSAAirq3tiLY6fkNqvjThLnCofL7363YkaScy/goupnp/ssdp
gx/ipfs/QmVwfv63beSAAirq3tiLY6fkNqvjThLnCofL7363YkaScy/goupnp/dcps/internetgateway1
gx/ipfs/QmVwfv63beSAAirq3tiLY6fkNqvjThLnCofL7363YkaScy/goupnp/dcps/internetgateway2
gx/ipfs/QmYsYNh6saxUYHajdj49uiRzdxQgiFTtymrjf3d1f2Cer4/go-nat-pmp
gx/ipfs/Qmf2fBLzCvFxs3vvZaoQyKSTv2rjApek4F1kzRxAfK6P4P/gateway
gx/ipfs/QmPfFaAVvKzacBFh2UBqUzczkPNQxGcLyAXKKD1hjC22re/go-nat
gx/ipfs/QmeQW4ayVqi7Jjay1SrP2wYydsH9KwSrzQBnqyC25gPFnG/go-notifier/Godeps/_workspace/src/github.com/jbenet/goprocess
gx/ipfs/QmeQW4ayVqi7Jjay1SrP2wYydsH9KwSrzQBnqyC25gPFnG/go-notifier/Godeps/_workspace/src/github.com/jbenet/goprocess/ratelimit
gx/ipfs/QmW25V77H8nb1ucUe8BDUbR3QXLNzTearBLYMW5DqDVWd5/go-libp2p-nat
gx/ipfs/QmY51bqSM5XgxQZqsBrQcRkKTnCb8EKpJpR9K6Qax7Njco/go-libp2p/p2p/protocol/identify/pb
gx/ipfs/QmY51bqSM5XgxQZqsBrQcRkKTnCb8EKpJpR9K6Qax7Njco/go-libp2p/p2p/host/basic
gx/ipfs/QmdVrMn1LhB4ybb8hMVaMLXnA8XRSewMnK6YqXKXoTcRvN/go-libp2p-peer/test
gx/ipfs/QmcW4FGAt24fdK1jBgWQn3yP4R9ZLyWQqjozv9QK7epRhL/go-testutil
gx/ipfs/QmcxUtMB5sJrXR3znSvkrDd2ghvwGM8rLRqwJiPUdgQwat/go-libp2p-netutil
gx/ipfs/QmY51bqSM5XgxQZqsBrQcRkKTnCb8EKpJpR9K6Qax7Njco/go-libp2p/p2p/net/mock
gx/ipfs/QmbFRJeEmEU16y3BmKKaD4a9fm5oHsEAMHe2vSB1UnfLMi/go-ipfs-routing/offline
gx/ipfs/QmbFRJeEmEU16y3BmKKaD4a9fm5oHsEAMHe2vSB1UnfLMi/go-ipfs-routing/mock
gx/ipfs/QmSLYFS88MpPsszqWdhGSxvHyoTnmaU4A74SD6KGib6Z3m/go-bitswap/testnet
gx/ipfs/QmeiCcJfDW1GJnWUArudsv5rQsihpi4oyddPhdqo3CfX6i/go-datastore/delayed
gx/ipfs/QmSMZwvs3n4GBikZ7hKzT17c3bk65FmyZo2JqtJ16swqCv/multiaddr-filter
[] gx/ipfs/QmeoWapXvjjwRqLczX6ufvPTk6w8xzso35AoYNa8PRrDKs/go-reuseport
gx/ipfs/QmZH5VXfAJouGMyCCHTRPGCT3e5MG9Lu78Ln3YAYW1XTts/websocket
gx/ipfs/QmX4UrmHGPnFxwfsunZjPbykzyv8Frg9AVmNariXqrLsMs/go-ws-transport
gx/ipfs/QmW7VUmSvhvSGbYbdsh7uRjhGmsYkc9fL8aJ5CorxxrU5N/go-crypto/blowfish
gx/ipfs/QmXzYnwYnJiDDV9y4QmbmtSeVyJ1R8HAmGnrnY2D6G3YcV/go-libp2p-secio/pb
gx/ipfs/QmWzjXAyBTygw6CeCTUnhJzhFucfxY5FJivSoiGuiSbPjS/go-smux-multistream
gx/ipfs/QmYMGCwtKbLXfh2MUTbLoP66N9Y24DSg8PFJRG21eE2qwv/go-conn-security/insecure
gx/ipfs/QmZaZ4nkadScQtG7KaGUWyh24jz5tD8d6AyetJmGnMo49t/go-conn-security-multistream
gx/ipfs/QmQFXpvKpF34dK9HcE7k8Ksk8V4BwWYZtdEcjzu5aUgRVr/go-flow-metrics
gx/ipfs/QmcoBbyTiL9PFjo1GFixJwqQ8mZLJ36CribuqyKmS1okPu/go-libp2p-metrics
gx/ipfs/QmXvBj8ojY4GdR4a2pVwFtmSK7HJ5JxSCGjY5zYNUkcPff/go-addr-util
gx/ipfs/QmemVjhp1UuWPQqrWSvPcaqH3QJRMjMqNm4T2RULMkDDQe/go-libp2p-swarm
gx/ipfs/QmY51bqSM5XgxQZqsBrQcRkKTnCb8EKpJpR9K6Qax7Njco/go-libp2p/config
gx/ipfs/QmRgLNKyQBZSCh4UJHy1gJ3VbhPpByprv6WTEi7G7qG2Lm/go-multiplex
gx/ipfs/QmZHiqdRuNXujvSPNu1ZWxxzV6a2WhoZpfYkesdgyaKF9f/go-smux-multiplex
gx/ipfs/QmZt87ZHYGaZFBrtGPEqYjAC2yNAhgiRDBmu8KaCzHjx6h/yamux
gx/ipfs/QmcsgrV3nCAKjiHKZhKVXWc4oY3WBECJCqahXEMpHeMrev/go-smux-yamux
gx/ipfs/QmRvYNctevGUW52urgmoFZscT6buMKqhHezLUS64WepGWn/go-net/bpf
gx/ipfs/QmRvYNctevGUW52urgmoFZscT6buMKqhHezLUS64WepGWn/go-net/internal/iana
gx/ipfs/QmRvYNctevGUW52urgmoFZscT6buMKqhHezLUS64WepGWn/go-net/internal/socket
gx/ipfs/QmRvYNctevGUW52urgmoFZscT6buMKqhHezLUS64WepGWn/go-net/ipv4
gx/ipfs/QmRvYNctevGUW52urgmoFZscT6buMKqhHezLUS64WepGWn/go-net/ipv6
gx/ipfs/QmW7VUmSvhvSGbYbdsh7uRjhGmsYkc9fL8aJ5CorxxrU5N/go-crypto/ed25519/internal/edwards25519
gx/ipfs/QmV3bVtkAhSZqWncYGonUmsVcJcV6cpzWztsFwc3A9so5m/dns
gx/ipfs/QmNeRzgrSpwbMU7VKLRyfvbqf1nRrAiQ7fEXaBxWGT5Ygr/mdns
gx/ipfs/QmY51bqSM5XgxQZqsBrQcRkKTnCb8EKpJpR9K6Qax7Njco/go-libp2p/p2p/discovery
gx/ipfs/QmY51bqSM5XgxQZqsBrQcRkKTnCb8EKpJpR9K6Qax7Njco/go-libp2p/p2p/host/routed
gx/ipfs/QmY51bqSM5XgxQZqsBrQcRkKTnCb8EKpJpR9K6Qax7Njco/go-libp2p/p2p/protocol/ping
gx/ipfs/QmYAL9JsqVVPFWwM1ZzHNsofmTzRYQHJ2KqQaBmFJjJsNx/go-libp2p-connmgr
gx/ipfs/QmYKNMEUK7nCVAefgXF1LVtZEZg3uRmBqiae4FJRXDNAyJ/go-path/resolver
gx/ipfs/QmbFRJeEmEU16y3BmKKaD4a9fm5oHsEAMHe2vSB1UnfLMi/go-ipfs-routing/none
gx/ipfs/QmeiCcJfDW1GJnWUArudsv5rQsihpi4oyddPhdqo3CfX6i/go-datastore/retrystore
gx/ipfs/QmSaz8Qg77gGqvDvLKeSAY7ivDEnramSWF6T7TcRwFpHtP/go-unixfs/importer/balanced
gx/ipfs/QmdZ4PvPHFQVLLEve7DgoKDcSY19wwpGBB1GKjjKi2rEL1/dir-index-html
github.com/ipfs/go-ipfs/cmd/ipfs/util
gx/ipfs/QmNueRyPRQiV7PUEpnP4GgGLuK1rKQLaRW7sfPvUetYig1/go-ipfs-cmds
github.com/ipfs/go-ipfs/blocks/blockstoreutil
github.com/ipfs/go-ipfs/core/commands/e
github.com/ipfs/go-ipfs/core/coredag
github.com/ipfs/go-ipfs/pin/gc
github.com/ipfs/go-ipfs/repo/common
github.com/ipfs/go-ipfs/repo/fsrepo/migrations
gx/ipfs/QmdYwCmx8pZRkzdcd8MhmLJqYVoVTC1aGsy5Q4reMGLNLg/atomicfile
github.com/ipfs/go-ipfs/repo/fsrepo/serialize
github.com/ipfs/go-ipfs/thirdparty/dir
gx/ipfs/QmPMRquZA1WiRMQ5ZE2V1kHtnPaq2X5Qtz7Wgwwo2tjLyS/go-ds-measure
gx/ipfs/QmPSBJL4momYnE7DcUyk2DVhD6rH488ZmHBGLbxNdhU44K/go-humanize
gx/ipfs/QmXuBJ7DR6k3rmUEKtvVMhwjmXDuJgXXPUt4LQXKBMsU93/go-os-helper
gx/ipfs/QmRFFHk2jw9tgjxv12bCuuTnSbVXxEvYQkuNCLMEv9eUwP/go-farm
gx/ipfs/QmRvYNctevGUW52urgmoFZscT6buMKqhHezLUS64WepGWn/go-net/internal/timeseries
gx/ipfs/QmRvYNctevGUW52urgmoFZscT6buMKqhHezLUS64WepGWn/go-net/trace
gx/ipfs/QmVmDhyTTUcQXFD1rRQ64fGLMSAoaQvNH3hwuaCFAPq2hy/errors
gx/ipfs/Qmb3GBFCHMuzmi9EpH3pxpYBiviyc3tEPyDQHxZJQJSxj9/badger/options
gx/ipfs/Qmb3GBFCHMuzmi9EpH3pxpYBiviyc3tEPyDQHxZJQJSxj9/badger/protos
[] gx/ipfs/Qmb3GBFCHMuzmi9EpH3pxpYBiviyc3tEPyDQHxZJQJSxj9/badger/y
gx/ipfs/QmYDxsntDcWC7CTisDmeorEvDVjkRAjjY9Vr9DJ6HSkXMS/go4-lock
gx/ipfs/QmYzCZUe9CBDkyPNPcRNqXQK8KKhtUfXvc88PkFujAEJPe/go-fs-lock
gx/ipfs/QmbBhyDKsY4mbY6xsKt3qu9Y7FPvMJ6qbD8AMjYYvPRw1g/goleveldb/leveldb/util
gx/ipfs/QmbBhyDKsY4mbY6xsKt3qu9Y7FPvMJ6qbD8AMjYYvPRw1g/goleveldb/leveldb/cache
gx/ipfs/QmbBhyDKsY4mbY6xsKt3qu9Y7FPvMJ6qbD8AMjYYvPRw1g/goleveldb/leveldb/comparer
gx/ipfs/QmbBhyDKsY4mbY6xsKt3qu9Y7FPvMJ6qbD8AMjYYvPRw1g/goleveldb/leveldb/storage
gx/ipfs/QmbBhyDKsY4mbY6xsKt3qu9Y7FPvMJ6qbD8AMjYYvPRw1g/goleveldb/leveldb/errors
gx/ipfs/QmbBhyDKsY4mbY6xsKt3qu9Y7FPvMJ6qbD8AMjYYvPRw1g/goleveldb/leveldb/filter
gx/ipfs/QmbBhyDKsY4mbY6xsKt3qu9Y7FPvMJ6qbD8AMjYYvPRw1g/goleveldb/leveldb/iterator
gx/ipfs/QmbBhyDKsY4mbY6xsKt3qu9Y7FPvMJ6qbD8AMjYYvPRw1g/goleveldb/leveldb/journal
gx/ipfs/QmbBhyDKsY4mbY6xsKt3qu9Y7FPvMJ6qbD8AMjYYvPRw1g/goleveldb/leveldb/memdb
gx/ipfs/QmbBhyDKsY4mbY6xsKt3qu9Y7FPvMJ6qbD8AMjYYvPRw1g/goleveldb/leveldb/opt
gx/ipfs/QmNtxDQBrVzy88FEjVikyM5tAbyfnHm5jJbJZcUhVykusq/snappy
gx/ipfs/QmbBhyDKsY4mbY6xsKt3qu9Y7FPvMJ6qbD8AMjYYvPRw1g/goleveldb/leveldb/table
gx/ipfs/Qmb4NghN5y3uGjiZCQWU6g1ZWRVmFCykLmByqxEVi7px1d/go-ds-leveldb
gx/ipfs/Qmc1ExJkrEUesbvRNHq6g3bJ2km7K4XffcC2bvwdpfGYDx/go-ds-flatfs
gx/ipfs/QmeiCcJfDW1GJnWUArudsv5rQsihpi4oyddPhdqo3CfX6i/go-datastore/mount
github.com/ipfs/go-ipfs/tar
gx/ipfs/QmNu2sEu7LuoBQbnSoy8u6wk6oWwFX8L5nVVUZoK7J67oQ/go-runewidth
gx/ipfs/QmPtj12fdwuAqj9sBSTNUxBNu8kCGNp8b3o8yUzMm5GHpq/pb
gx/ipfs/QmQine7gvHncNevKtG9QXxf3nXcwSj6aDDmMm52mHofEEp/tar-utils
gx/ipfs/QmRy4Qk9hbgFX9NGJRm8rBThrA8PZhNCitMgeRYyZ67s59/go-merkledag/test
gx/ipfs/QmSaz8Qg77gGqvDvLKeSAY7ivDEnramSWF6T7TcRwFpHtP/go-unixfs/archive/tar
gx/ipfs/QmZRjKbHa6DenStpQJFiaPcEwkZqrx7TH6xTf342LDU3qM/go-sysinfo
github.com/ipfs/go-ipfs/core/coreapi/interface/options
gx/ipfs/QmXMPT8tVwqKHZKWxnrfbYqUEaDJ5SF3Yh3fnFthaSrU37/xhandler
gx/ipfs/QmPG2kW5t27LuHgHnvhUwbHCNHAt2eUcb4gPHqofrESUdB/cors
gx/ipfs/QmNueRyPRQiV7PUEpnP4GgGLuK1rKQLaRW7sfPvUetYig1/go-ipfs-cmds/http
gx/ipfs/QmQzJ5r1Ku82GvPwMEPtFhq3S3ZtC5LnEsS8zhTMPBPYw3/golang_protobuf_extensions/pbutil
gx/ipfs/QmTWEDbLX2d4NiMgPks6J2crRz47BamBtP16WiFuTL6Ydm/common/internal/bitbucket.org/ww/goautoneg
gx/ipfs/QmTWEDbLX2d4NiMgPks6J2crRz47BamBtP16WiFuTL6Ydm/common/model
gx/ipfs/QmYaVovLzgcdBpCLEAnW41p8ujvCUxe3TFpfJxjK5qbzn7/client_model/go
gx/ipfs/QmTWEDbLX2d4NiMgPks6J2crRz47BamBtP16WiFuTL6Ydm/common/expfmt
gx/ipfs/QmbNinL4ErzM73BxQSNf8q2vPmAM4v3MNQM2DmDqDjt47D/perks/quantile
gx/ipfs/QmdCgRBcahWLSq3a2xdbcPb4ksrRREAhisYdfAaGfJ8hWb/procfs/internal/util
gx/ipfs/QmdCgRBcahWLSq3a2xdbcPb4ksrRREAhisYdfAaGfJ8hWb/procfs/nfs
gx/ipfs/QmdCgRBcahWLSq3a2xdbcPb4ksrRREAhisYdfAaGfJ8hWb/procfs/xfs
gx/ipfs/QmYYv3QFnfQbiwmi1tpkgKF8o4xFnZoBrvpupTiGJwL9nH/client_golang/prometheus
github.com/ipfs/go-ipfs/plugin
gx/ipfs/QmarUgTjwokWN8NyEuvRP5gSsJQpDecpRJEKxAi31pM7XX/go-ipld-git
github.com/ipfs/go-ipfs/plugin/plugins/git
github.com/ipfs/go-ipfs/plugin/loader
gx/ipfs/QmTVvctiHWZzSDZdyU5wdnXh7VF3kprHSyQFwVChos5qKu/golang-levenshtein/levenshtein
gx/ipfs/QmNueRyPRQiV7PUEpnP4GgGLuK1rKQLaRW7sfPvUetYig1/go-ipfs-cmds/cli
gx/ipfs/QmUDtdqVcetYfRUnfhzrRQzPSgW1gf57MsMQSiLZpNkjbg/go-metrics-prometheus
gmake: *** [install_unsupported] Error 2
It looks like it might be worth opening an issue on the go-ipfs issue tracker. I found two open issues for building on OpenBSD (not sure whether they are still issues), but this looks like a new one.
I think the my problems are related with go on Unix.
I ran the go command, ‘go build -x’ in the directory, go-reuseport, and found the some go files are missing.
ts75@sol:~/goApp/src/gx/ipfs/QmeoWapXvjjwRqLczX6ufvPTk6w8xzso35AoYNa8PRrDKs/go-reuseport$ ls
LICENSE addr.go impl_unix.go opts_posix.go reuse_test.go
Makefile available_unix.go impl_windows.go package.json singlepoll
README.md codecov.yml interface.go poll test
ts75@sol:~/goApp/src/gx/ipfs/QmeoWapXvjjwRqLczX6ufvPTk6w8xzso35AoYNa8PRrDKs/go-reuseport$ go build -x
WORK=/tmp/go-build011452066
mkdir -p $WORK/b001/
cat >$WORK/b001/importcfg << ‘EOF’ # internal
- import config
packagefile context=/export/home/ts75/go/pkg/solaris_amd64/context.a
packagefile errors=/export/home/ts75/go/pkg/solaris_amd64/errors.a
packagefile gx/ipfs/QmVGjyM9i2msKvLXwh9VosCTgP4mL91kC7hDmqnwTTx6Hu/sys/unix=/export/home/ts75/.cache/go-build/55/55ce16f6fb9305ff1d8a277cbd00d9c237c46bbf0a2efee159d9adee60742c3d-d
packagefile net=/export/home/ts75/go/pkg/solaris_amd64/net.a
packagefile os=/export/home/ts75/go/pkg/solaris_amd64/os.a
packagefile syscall=/export/home/ts75/go/pkg/solaris_amd64/syscall.a
packagefile time=/export/home/ts75/go/pkg/solaris_amd64/time.a
EOF
cd /export/home/ts75/goApp/src/gx/ipfs/QmeoWapXvjjwRqLczX6ufvPTk6w8xzso35AoYNa8PRrDKs/go-reuseport
/export/home/ts75/go/pkg/tool/solaris_amd64/compile -o $WORK/b001/pkg.a -trimpath $WORK/b001 -p gx/ipfs/QmeoWapXvjjwRqLczX6ufvPTk6w8xzso35AoYNa8PRrDKs/go-reuseport -complete -buildid -DC4OwKpMXpfy_N4Cm05/-DC4OwKpMXpfy_N4Cm05 -goversion go1.10.3 -D “” -importcfg $WORK/b001/importcfg -pack ./addr.go ./interface.go ./opts_posix.go
- gx/ipfs/QmeoWapXvjjwRqLczX6ufvPTk6w8xzso35AoYNa8PRrDKs/go-reuseport
./interface.go:33:9: undefined: available
./interface.go:50:6: undefined: available
./interface.go:54:9: undefined: listenStream
./interface.go:61:6: undefined: available
./interface.go:65:9: undefined: listenPacket
./interface.go:72:6: undefined: available
./interface.go:102:6: undefined: available
./interface.go:106:9: undefined: dial
