Go-libp2p-core source code routing.go
Where is the implementation of the provide method defined by the Contentrouting interface in this file? Thank you for your answer
type ContentRouting interface {
// Provide adds the given cid to the content routing system. If 'true' is
// passed, it also announces it, otherwise it is just kept in the local
// accounting of which objects are being provided.
Provide(context.Context, cid.Cid, bool) error
// Search for peers who are able to provide a given key
// When count is 0, this method will return an unbounded number of
// results.
FindProvidersAsync(context.Context, cid.Cid, int) <-chan peer.AddrInfo
The URL for this file is (GitHub - libp2p/go-libp2p-core: Interfaces and abstractions that make up go-libp2p). Can someone tell me where exactly the implementation of the provide function for the “contentrouting” interface definition is
thanks a lot!!!
Hi, Hector! I have a new problem, the same URL, the code in the go-libp2p-core directory, where is the implementation of the network package?A portion of the code for this interface is listed below.
thanks a lot!!!
type Network interface {
Dialer
io.Closer
// SetStreamHandler sets the handler for new streams opened by the
// remote side. This operation is threadsafe.
SetStreamHandler(StreamHandler)
// NewStream returns a new stream to given peer p.
// If there is no connection to p, attempts to create one.
NewStream(context.Context, peer.ID) (Stream, error)
// Listen tells the network to start listening on given multiaddrs.
Listen(...ma.Multiaddr) error
// ListenAddresses returns a list of addresses at which this network listens.
ListenAddresses() []ma.Multiaddr
// InterfaceListenAddresses returns a list of addresses at which this network
// listens. It expands "any interface" addresses (/ip4/0.0.0.0, /ip6/::) to
// use the known local interfaces.
InterfaceListenAddresses() ([]ma.Multiaddr, error)
io.Closer
// Dialer represents a service that can dial out to peers
// (this is usually just a Network, but other services may not need the whole
// stack, and thus it becomes easier to mock)
type Dialer interface {
// Peerstore returns the internal peerstore
// This is useful to tell the dialer about a new address for a peer.
// Or use one of the public keys found out over the network.
Peerstore() peerstore.Peerstore
// LocalPeer returns the local peer associated with this network
LocalPeer() peer.ID
// DialPeer establishes a connection to a given peer
DialPeer(context.Context, peer.ID) (Conn, error)
// ClosePeer closes the connection to a given peer
ClosePeer(peer.ID) error
// Connectedness returns a state signaling connection capabilities
Connectedness(peer.ID) Connectedness
// Peers returns the peers connected
Peers() []peer.ID
// Conns returns the connections in this Netowrk
Conns() []Conn
// ConnsToPeer returns the connections in this Netowrk for given peer.
ConnsToPeer(p peer.ID) []Conn
// Notify/StopNotify register and unregister a notifiee for signals
Notify(Notifiee)
StopNotify(Notifiee)
Here I think: GitHub - libp2p/go-libp2p-swarm: The libp2p swarm manages groups of connections to peers, and handles incoming and outgoing streams
