Help regarding ipfs cat CID waiting too long to show the content which I added through ipfs example
I am new to ipfs and very interested it. I was currently playing around the official example at https://github.com/ipfs/js-ipfs/tree/master/examples/browser-browserify and I also started an ipfs daemon from terminal. I encountered below issue which I don’t think it’s right so I need help.
First, I add data to IPFS from the browser and then the example show the content’s CID is QmYb6NEo6CwAzCqY5UNMMUavvtDmBtgHY3QR65oP8JnKPP
Second, I use command line “ipfs cat QmYb6NEo6CwAzCqY5UNMMUavvtDmBtgHY3QR65oP8JnKPP” and the command executed forever.
From what I have learned from doc, it should return the content. Am I missing something? The example is using “ipfs”: “^0.50.1”,
check and see if there’s anything in the logs…
(this below is a link to the #ipfs-log part of the docs)
You may need to set the debug level to DEBUG and try again.
thanks for the information. I didn’t find any useful information though.
However, I found it might due to the VPN I am using, sometime the ipfs cat work sometime not. I will try again in a better network env.
