How can I can create IPFS node with bandwidth limit controls PER FILE?
I want to create as the title says an IPFS node where I have control over bandwidth limits per file. Any client works but if this could be done in js-ipfs that would be ideal. I’ve looked through their api but can only find stats for bandwidth per peer not per file. I haven’t been able to find anything similar for other clients as well.
Thanks in advance
