How do I add a file to http using ipfs? (without path)
I kinda just want to send to the api a file name (I actually don’t even care about it) I just want to give it “ABC” and let it return a CID to me.
I am fine for sepcifying what location in the DAG I want the file to be, I just want to start from this simple thing.
if there is a documentation I can read it myself too, didn’t seem to find a way to add a file without it already existing when I was reading HTTP API | IPFS Docs (ipns.localhost) though
To add files you would use ipfs add but I don’t understand what you mean by just a file name.
The DAG API is different then files, it allow structured data to be turned into blocks and linked to form DAGs.
I usually use json when using ipfs dag put
Docs → https://docs.ipfs.io/reference/cli/#ipfs-dag
I would like an example to add one file to ipfs, I am wondering how can you do it, without giving the path.
Like, what does it mean by path? how can I add a file?
is it a file system path on my machine like C:\Program Files(x86) or can it also be Google ?
the doc doesn’t say much
I am looking at HTTP API | IPFS Docs (ipns.localhost)
I hope someone can tell me if I can use http post to /api/v0/add
Then specify
name="<filename>"; filename="<file system path>"
In the header.
and then add the content of the file in the request body.
Is it possible to upload “ABC” to ipfs and add a file that contains “ABC”
The way you ask your question is actually very confusing, but I’m going to take a stab at it. Here is an example of what you can do with the cli:
> echo "hello worlds" | ipfs add
added QmZ4tDuvesekSs4qM5ZBKpXiZGun7S2CYtEZRB3DYXkjGx
> ipfs cat QmZ4tDuvesekSs4qM5ZBKpXiZGun7S2CYtEZRB3DYXkjGx
hello worlds
Once you have done that, you can use the following address to reach that file using an ipfs capable browser:
/ipfs/QmZ4tDuvesekSs4qM5ZBKpXiZGun7S2CYtEZRB3DYXkjGx
or
ipfs://QmZ4tDuvesekSs4qM5ZBKpXiZGun7S2CYtEZRB3DYXkjGx
Or, you could load it using a gateway, like this:
https://dweb.link/ipfs/QmZ4tDuvesekSs4qM5ZBKpXiZGun7S2CYtEZRB3DYXkjGx
Now, you could upload a folder structure instead, and then append a path into that structure when retrieving a file. What you cannot do, ever, is start with a path. Your address must start with a cid (or an ipns address pointing to a cid), optionally followed by a path if the cid points to a folder structure.
Does this help?
I am trying to do it using http, do I put “Hello World” in the request body and that’s it?
You input was a good starting point for me too
also when I am using api/v0/pin/ls it’s not working
> echo "hello worlds" > hello.txt
> curl -X POST -F file=@hello.txt "http://localhost:5001/api/v0/add"
{"Name":"hello.txt","Hash":"QmZ4tDuvesekSs4qM5ZBKpXiZGun7S2CYtEZRB3DYXkjGx","Size":"21"}
hello worlds
What if I don’t want to use a file what if it’s an api in remote location what if I just want to give the string “hello world” to the api and it gives me back CID
class payload
    public string? content;
public class Program
    public static async Task Main(string[] args)
        HttpClient httpClient = new HttpClient();
        var pl = new payload
            content = "ABC"
        var content = new StringContent(JsonSerializer.Serialize(pl, new JsonSerializerOptions
            IncludeFields = true,
            DefaultIgnoreCondition = System.Text.Json.Serialization.JsonIgnoreCondition.WhenWritingNull
        }), Encoding.UTF8, "application/json");
        var res = await httpClient.PostAsync("http://localhost:5002/api/v0/add", content);
        Console.WriteLine(await res.Content.ReadAsStringAsync());
I wrote a expample program in c# to post to my api
and I get
file argument 'path' is required
and I thought it’s ok to ignore path
js-ipfs/FILES.md at master · ipfs/js-ipfs (github.com)
I am looking at HTTP API | IPFS Docs (ipns.localhost), but it looks impossible to use. I am using c# trying to post data.
this doesn’t work :
                data="wadjaoidwjawdi"
            var res = await httpClient.PostAsync("http://localhost:60003/api/v0/files/write?create=true&arg=abc", content);
it keeps telling me the data is missing
I don’t want to tell ipfs where my file is, I just want to tell ipfs here’s “Hello Wrold”, put it in a file or an object whatever, then I get CID that I can use later
