I want to set up circuit-relaying.
I looked at an example https://github.com/ipfs/js-ipfs/tree/master/examples/circuit-relaying
But it didn’t work for me.
When I start daemon I see the following.
js-ipfs version: 0.48.1
System version: x64 / linux
Node.js version: 13.11.0
Swarm listening on /ip4/127.0.0.1/tcp/4002/p2p/QmYnyhZ9MiGagL2juEf7DGthNG76kbRUmVMA4Ktf83SCKm
Swarm listening on /ip4/192.168.100.3/tcp/4002/p2p/QmYnyhZ9MiGagL2juEf7DGthNG76kbRUmVMA4Ktf83SCKm
Swarm listening on /ip4/127.0.0.1/tcp/4003/ws/p2p/QmYnyhZ9MiGagL2juEf7DGthNG76kbRUmVMA4Ktf83SCKm
API listening on /ip4/127.0.0.1/tcp/7070/http
Gateway (read only) listening on /ip4/127.0.0.1/tcp/9090/http
Daemon is ready
How can I enable circuit-relaying or auto relay in the config?
This config doesn’t work
"relay": {
"enabled": true,
"hop": {
"enabled": true
