I want to check connection to my node. Doing ipfs swarm connect works:
$ ipfs swarm connect /dns/<domain>/tcp/4441/p2p/<peerid>/
connect <peerid> success
But then, looking at ipfs swarm addrs for this peerid, I see only indirect connections (through p2p-circuit). I am on a VPS with open ports, I am running inside docker by binding ports :
# in my docker-compose.yml
ports:
# p2p port public
- 4441:4001/tcp
- 4441:4001/udp
And I made it clear for kubo in the config file:
"Addresses": {
"Announce": [
"/dns/<domain>/tcp/4441",
"/dns/<domain>/udp/4441/quic-v1",
"/dns/<domain>/udp/4441/quic-v1/webtransport",
"/dns/<domain>/udp/4441/webrtc-direct"
"AppendAnnounce": [],
"Swarm": [
"/ip4/0.0.0.0/tcp/4001",
"/ip6/::/tcp/4001",
"/ip6/::/udp/4001/quic-v1",
"/ip6/::/udp/4001/quic-v1/webtransport",
"/ip4/0.0.0.0/udp/4001/webrtc-direct",
"/ip6/::/udp/4001/webrtc-direct"
My node is silently not announcing what I asked him, when I do ipfs id on the remote node, I see only p2p-circuit multiaddresses.
