Version
ipfs version 0.25.0
Config
"API": {
"HTTPHeaders": {}
"Addresses": {
"Announce": [],
"AppendAnnounce": [],
"NoAnnounce": [],
"Swarm": [
"/ip4/0.0.0.0/tcp/4001",
"/ip6/::/tcp/4001",
"/ip4/0.0.0.0/udp/4001/quic",
"/ip6/::/udp/4001/quic",
"/ip6/::/udp/4001/quic-v1",
"AutoNAT": {},
"Bootstrap": [
"/ip4/12.17.14.141/tcp/4001/p2p/12E3KooJLq6rP69XfrWJkkKN29fsvhX5z5hZe5SYUai6guhMhLya"
"DHT": {
"Server": true
"DNS": {
"Resolvers": {}
"Datastore": {
"BloomFilterSize": 0,
"GCPeriod": "1h",
"HashOnRead": false,
"Spec": {
"mounts": [
"child": {
"path": "blocks",
"sync": true,
"type": "flatfs"
"mountpoint": "/blocks",
"prefix": "flatfs.datastore",
"type": "measure"
"child": {
"compression": "none",
"path": "datastore",
"type": "levelds"
"mountpoint": "/",
"type": "measure"
"type": "mount"
"StorageGCWatermark": 90,
"StorageMax": "10GB"
"Discovery": {
"MDNS": {
"Enabled": true
"Experimental": {
"AcceleratedDHTClient": true,
"FilestoreEnabled": false,
"GraphsyncEnabled": false,
"OptimisticProvide": false,
"P2pHttpProxy": false,
"StrategicProviding": false,
"UrlstoreEnabled": false
"Gateway": {
"APICommands": [],
"HTTPHeaders": {
"X-Requested-With",
"Range",
"User-Agent"
"GET"
"NoDNSLink": false,
"NoFetch": false,
"PathPrefixes": [],
"PublicGateways": null,
"RootRedirect": ""
"Identity": {
"PeerID": "12D3KooWAAUpb6sUWUkdGngrMTb4QgjokRVxWghmG5FeG7QqJjNz"
"Internal": {},
"Ipns": {
"RecordLifetime": "",
"RepublishPeriod": "",
"ResolveCacheSize": 128
"Migration": {
"DownloadSources": [],
"Keep": ""
"Mounts": {
"FuseAllowOther": false,
"IPFS": "/ipfs",
"IPNS": "/ipns"
"Peering": {
"Peers": null
"Pinning": {
"RemoteServices": {}
"Plugins": {
"Plugins": null
"Provider": {
"Strategy": ""
"Pubsub": {
"DisableSigning": false,
"Router": ""
"Reprovider": {},
"Routing": {
"Methods": null,
"Routers": null,
"Type": "dhtserver"
"Swarm": {
"AddrFilters": null,
"ConnMgr": {},
"DisableNatPortMap": false,
"RelayClient": {},
"RelayService": {},
"ResourceMgr": {
"Limits": {}
"Transports": {
"Multiplexers": {},
"Network": {},
"Security": {}
Description
[ NodeB ↔ NodeA ] <==>[ Node0 ↔ Node3 ]
I have four nodes NodeB, NodeA, Node0, and Node3
NodeB is peer of NodeA,
NodeA is peer of NodeB and Node0
Node0 is a peer of NodeA and Node3
Node3 is a peer of Node3
When I upload file on NodeB it is accessible on NodeA but not on Node0 and Node3 as these nodes are not directly added as peer but have same swarm key. what might be the reason?
I have configured all nodes as dhtserver and turned the dht server check to “active” but its not working.
When we get content from direct peer node, content is retrieved but for indirect peer the content is not accessible directly
What I’ve Already tried
- Updated config with Routing.Type: dhtserver and dhtclient
- Updated config with DHT.Server: true
- Updated config with Tested with AccelaratedDHTClient: true
- manually announced the CID using ipfs dht provide then tried to fetch it using ipfs dht findprovs but no peer was returned.
- Tried annoucing using ipfs dht provide -r
- Tried with ipfs bitswap reprovide (command did not work)
What I get when i run ipfs stats dht
DHT wan (0 peers):
Bucket 0 (0 peers) - refreshed never:
Peer last useful last queried Agent Version
Error: no LAN client found
