How to set Kubo on a RPi to an attached storage?
How to set Kubo on a RPi/Ubuntu to an attached storage/SSD?
First, I’ve tried to change “Datastore”: { { "mounts": [ { "child": { "path": "/<NEWPATH>"}, but I ended up with…
Error: datastore configuration of ‘{“mounts”:[{...}’ does not match what is on disk ‘{“mounts”:[{...}
Then, I tried ipfs config Datastore.Path <newpath>, and it ended up with…
~$ ipfs swarm peers
Error: old style datatstore config detected
I also tried to simply move the entire ./ipfs folder to the SSD, but when I try “ipfs daemon”, I get a…
Error: no IPFS repo found in /home/<ORIGINAL>/.ipfs.
please run: 'ipfs init
I also get the same error above if I try to run ipfs init directly from the SSD.
Thanks in advance for the help :pray:t4:
I’m going to close this as duplicate to How to update the storage location? and answering there.
