Hi guys,
I am currently configuring my IPFS to use S3 as its datastore.
I used these cmds
ipfs init --profile server
ipfs config --json Datastore.Spec.mounts "[{\"child\":{\"type\":\"s3ds\",\"region\":\"$S3_REGION\",\"bucket\":\"$S3_BUCKET\",\"rootDirectory\":\"$S3_DIR\",\"accessKey\":\"$S3_ACCESS_KEY\",\"secretKey\":\"$S3_PRIVATE_KEY\"},\"mountpoint\":\"/blocks\",\"prefix\":\"s3.datastore\",\"type\":\"measure\"},{\"child\":{\"compression\":\"none\",\"path\":\"datastore\",\"type\":\"levelds\"},\"mountpoint\":\"/\",\"prefix\":\"leveldb.datastore\",\"type\":\"measure\"}]"
echo "{\"mounts\":[{\"bucket\":\"$S3_BUCKET\",\"mountpoint\":\"/blocks\",\"region\":\"$S3_REGION\",\"rootDirectory\":\"$S3_DIR\"},{\"mountpoint\":\"/\",\"path\":\"datastore\",\"type\":\"levelds\"}],\"type\":\"mount\"}" > $IPFS_PATH/datastore_spec
ipfs daemon --migrate=true --agent-version-suffix=docker
And encounter the error
Error: datastore configuration of '{"mounts":[{"mountpoint":"/blocks","path":"blocks","shardFunc":"/repo/flatfs/shard/v1/next-to-last/2","type":"flatfs"},{"mountpoint":"/","path":"datastore","type":"levelds"}],"type":"mount"}' does not match what is on disk '{"mounts":[{"bucket":"my-test-bucket","mountpoint":"/blocks","region":"ap-southeast-1","rootDirectory":"my-test-directory"},{"mountpoint":"/","path":"datastore","type":"levelds"}],"type":"mount"}'
I am aware that IPFS has a mechanism to prevent the mismatch config of datastore. So I tried to let IPFS generate the datastore_spec itself by follow the following cmds
// trying to re-init IPFS
mv $IPFS_PATH/config /somewhere/config.temp
rm -rf $IPFS_PATH/datastore_spec
ipfs init /somewhere/config.temp
rm /somewhere/config.temp
// start daemon
This works.
But I wonder if this is a correct way to re-init the IPFS to configure datastore.
Please give me your advice.
Thanks in advance.
