I have custom build based on the go-ds-s3 plugin which was working until I restarted the node. I datastore settings like this
"Datastore": {
"BloomFilterSize": 0,
"GCPeriod": "1h",
"HashOnRead": false,
"Spec": {
"mounts": [
"child": {
"accessKey": "",
"secretKey": "",
"bucket": "",
"region": "eu-central-2",
"regionEndpoint": "",
"rootDirectory": "/ipfs_test",
"type": "s3ds"
"mountpoint": "/",
"prefix": "s3.datastore",
"type": "measure"
"type": "mount"
"StorageGCWatermark": 90,
"StorageMax": "20000GB"
Which indeed creates directories like you can see on the screenshot.
The local contains one file only
while pins contain few more.
Now when I want to upload a file it all goes smoothly, the thing is it will refuse to pin it
The only error that is shown is ERROR core/commands/cmdenv pin/pin.go:133 context cancele
I’d like to know if is it even possible to use this plugin in the production environment or not.
