Problem Go-ds-s3 plugin IPFS GC
@hector
when running ipfs repo gc getting below error when using is with Go-ds-s3 plugin.
`2023-05-23T19:55:28.537Z	DEBUG	cmd/ipfs	ipfs/main.go:151	config path is /data/ipfs Error: could not retrieve links for QmU5k7ter3RdjZXu3sHghsga1UQtrztnQxmTL22nPnsu3g: block was not found locally (offline): ipld: could not find QmU5k7ter3RdjZXu3sHghsga1UQtrztnQxmTL22nPnsu3g; could not retrieve links for QmQGiYLVAdSHJQKYFRTJZMG4BXBHqKperaZtyKGmCRLmsF: block was not found locally (offline): ipld: could not find QmQGiYLVAdSHJQKYFRTJZMG4BXBHqKperaZtyKGmCRLmsF; could not retrieve links for QmYCvbfNbCwFR45HiNP45rwJgvatpiW38D961L5qAhUM5Y: block was not found locally (offline): ipld: could not find QmYCvbfNbCwFR45HiNP45rwJgvatpiW38D961L5qAhUM5Y; could not retrieve links for QmQy6xmJhrcC5QLboAcGFcAE1tC8CrwDVkrHdEYJkLscrQ: block was not found locally (offline): ipld: could not find QmQy6xmJhrcC5QLboAcGFcAE1tC8CrwDVkrHdEYJkLscrQ; could not retrieve links for QmejvEPop4D7YUadeGqYWmZxHhLc4JBUCzJJHWMzdcMe2y: block was not found locally (offline): ipld: could not find QmejvEPop4D7YUadeGqYWmZxHhLc4JBUCzJJHWMzdcMe2y; could not retrieve links for QmQ5vhrL7uv6tuoN9KeVBwd4PwfQkXdVVmDLUZuTNxqgvm: block was not found locally (offline): ipld: could not find QmQ5vhrL7uv6tuoN9KeVBwd4PwfQkXdVVmDLUZuTNxqgvm; garbage collection aborted: could not retrieve some links`
also when running ipfs repo stat getting
NumObjects: 0 RepoSize: 69508 StorageMax: 10000000000 RepoPath: /data/ipfs Version: fs-repo@13
It seems your S3 repo has 0 objects. However, there must be something pinned in your ipfs node or something that makes GC want to traverse a dag starting with those CIDs.
I have no experience with go-ds-s3, but I’m also wondering if you have it wright, since RepoPath: /data/ipfs seems a bit suspicious.
@stebalien
Can you help me with this.
this is my configmap-bootstrap.yaml
 configure-ipfs.sh: |
    #!/bin/sh
    set -e
    set -x
    user=ipfs
    repo=/data/ipfs
    # This is a custom entrypoint for k8s designed to run ipfs nodes in an appropriate
    # setup for production scenarios.
    mkdir -p /data/ipfs && chown -R ipfs /data/ipfs
    if [ `id -u` -eq 0 ]; then
      echo "Changing user $user"
      echo ${ACCESS_KEY}
      echo ${SECRET_KEY}
      echo "******"
      # ensure folder is writable
      su-exec "$user" test -w "$repo" || chown -R -- "$user" "$repo"
      # restart script with new privileges
      exec su-exec "$user" sh "$0" "$@"
    fi
    if [ -f /data/ipfs/config ]; then
      if [ -f /data/ipfs/repo.lock ]; then
        rm /data/ipfs/repo.lock
      fi
      exit 0
    fi
    ipfs init
    ipfs config Addresses.API /ip4/0.0.0.0/tcp/5001
    ipfs config Addresses.Gateway /ip4/0.0.0.0/tcp/8080
    ipfs config --json Swarm.ConnMgr.HighWater 2000
    ipfs config --json Datastore.BloomFilterSize 1048576
    ipfs config Datastore.StorageMax 1GB
    ipfs config Datastore.GCPeriod 1h
    ipfs config --json API.HTTPHeaders.Access-Control-Allow-Origin '["*"]'
    ipfs config --json Datastore.Spec.mounts "[{\"child\":{\"type\":\"s3ds\",\"region\":\"us-east-1\",\"bucket\":\"dev-ipfs-cluster\",\"rootDirectory\":\"/\",\"accessKey\":\"${ACCESS_KEY}\",\"secretKey\":\"${SECRET_KEY}\"},\"mountpoint\":\"/blocks\",\"prefix\":\"s3.datastore\",\"type\":\"measure\"},{\"child\":{\"compression\":\"none\",\"path\":\"datastore\",\"type\":\"levelds\"},\"mountpoint\":\"/\",\"prefix\":\"leveldb.datastore\",\"type\":\"measure\"}]"
    echo "{\"mounts\":[{\"bucket\":\"dev-ipfs-cluster\",\"mountpoint\":\"/blocks\",\"region\":\"us-east-1\",\"rootDirectory\":\"/\"},{\"mountpoint\":\"/\",\"path\":\"datastore\",\"type\":\"levelds\"}],\"type\":\"mount\"}" > /data/ipfs/datastore_spec
    ipfs config --json API.HTTPHeaders.Access-Control-Allow-Methods '["PUT", "POST"]'
@stebalien
To be more specific here is my config file
  "API": {
    "HTTPHeaders": {
        "PUT",
        "POST"
  "Addresses": {
    "Announce": [],
    "AppendAnnounce": [],
    "NoAnnounce": [],
    "Swarm": [
      "/ip4/0.0.0.0/tcp/4001",
      "/ip6/::/tcp/4001",
      "/ip4/0.0.0.0/udp/4001/quic",
      "/ip6/::/udp/4001/quic",
      "/ip6/::/udp/4001/quic-v1",
  "AutoNAT": {},
  "Bootstrap": [
    "/ip4/104.131.131.82/udp/4001/quic/p2p/QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ",
    "/dnsaddr/bootstrap.libp2p.io/p2p/QmbLHAnMoJPWSCR5Zhtx6BHJX9KiKNN6tpvbUcqanj75Nb"
  "DNS": {
    "Resolvers": {}
  "Datastore": {
    "BloomFilterSize": 1048576,
    "GCPeriod": "1h",
    "HashOnRead": false,
    "Spec": {
      "mounts": [
          "child": {
            "accessKey": "",
            "bucket": "dev-ipfs-cluster",
            "region": "us-east-1",
            "rootDirectory": "/",
            "secretKey": "",
            "type": "s3ds"
          "mountpoint": "/blocks",
          "prefix": "s3.datastore",
          "type": "measure"
          "child": {
            "compression": "none",
            "path": "datastore",
            "type": "levelds"
          "mountpoint": "/",
          "type": "measure"
      "type": "mount"
    "StorageGCWatermark": 90,
    "StorageMax": "1GB"
  "Discovery": {
    "MDNS": {
      "Enabled": true
  "Experimental": {
    "FilestoreEnabled": false,
    "GraphsyncEnabled": false,
    "P2pHttpProxy": false,
    "StrategicProviding": false,
    "UrlstoreEnabled": false
  "Gateway": {
    "APICommands": [],
    "HTTPHeaders": {
        "X-Requested-With",
        "Range",
        "User-Agent"
        "GET"
    "NoDNSLink": false,
    "NoFetch": false,
    "PathPrefixes": [],
    "PublicGateways": null,
    "RootRedirect": ""
  "Identity": {
    "PeerID": "12D3KooWPS6DPSbosoTXgud9m3WRgZK7KXJY2HfzXqZCkpvavN9a",
    "PrivKey": "CAESQKwD4ke53e3MLGgbuHfZvaMbmhZ5yjyO1WNFf1pLuYrhyk7MqD6HbSA2sZTjjFploXy6D0fOmDaciufPKj/aXZ0="
  "Internal": {},
  "Ipns": {
    "RecordLifetime": "",
    "RepublishPeriod": "",
    "ResolveCacheSize": 128
  "Migration": {
    "DownloadSources": [],
    "Keep": ""
  "Mounts": {
    "FuseAllowOther": false,
    "IPFS": "/ipfs",
    "IPNS": "/ipns"
  "Peering": {
    "Peers": [
        "Addrs": [
          "/dnsaddr/fra1-1.hostnodes.pinata.cloud"
        "ID": "QmWaik1eJcGHq1ybTWe7sezRfqKNcDRNkeBaLnGwQJz1Cj"
        "Addrs": [
          "/dnsaddr/fra1-2.hostnodes.pinata.cloud"
        "ID": "QmNfpLrQQZr5Ns9FAJKpyzgnDL2GgC6xBug1yUZozKFgu4"
        "Addrs": [
          "/dnsaddr/fra1-3.hostnodes.pinata.cloud"
        "ID": "QmPo1ygpngghu5it8u4Mr3ym6SEU2Wp2wA66Z91Y1S1g29"
        "Addrs": [
          "/dnsaddr/nyc1-1.hostnodes.pinata.cloud"
        "ID": "QmRjLSisUCHVpFa5ELVvX3qVPfdxajxWJEHs9kN3EcxAW6"
        "Addrs": [
          "/dnsaddr/nyc1-2.hostnodes.pinata.cloud"
        "ID": "QmPySsdmbczdZYBpbi2oq2WMJ8ErbfxtkG8Mo192UHkfGP"
        "Addrs": [
          "/dnsaddr/nyc1-3.hostnodes.pinata.cloud"
        "ID": "QmSarArpxemsPESa6FNkmuu9iSE1QWqPX2R3Aw6f5jq4D5"
        "Addrs": [
          "/ip4/139.178.68.217/tcp/6744"
        "ID": "12D3KooWCVXs8P7iq6ao4XhfAmKWrEeuKFWCJgqe9jGDMTqHYBjw"
        "Addrs": [
          "/ip4/147.75.49.71/tcp/6745"
        "ID": "12D3KooWGBWx9gyUFTVQcKMTenQMSyE2ad9m7c9fpjS4NMjoDien"
        "Addrs": [
          "/ip4/147.75.86.255/tcp/6745"
        "ID": "12D3KooWFrnuj5o3tx4fGD2ZVJRyDqTdzGnU3XYXmBbWbc8Hs8Nd"
        "Addrs": [
          "/ip4/3.134.223.177/tcp/6745"
        "ID": "12D3KooWN8vAoGd6eurUSidcpLYguQiGZwt4eVgDvbgaS7kiGTup"
        "Addrs": [
          "/ip4/35.74.45.12/udp/6746/quic"
        "ID": "12D3KooWLV128pddyvoG6NBvoZw7sSrgpMTPtjnpu3mSmENqhtL7"
        "Addrs": [
          "/dnsaddr/node-1.ingress.cloudflare-ipfs.com"
        "ID": "QmcFf2FH3CEgTNHeMRGhN7HNHU1EXAxoEk6EFuSyXCsvRE"
        "Addrs": [
          "/dnsaddr/node-2.ingress.cloudflare-ipfs.com"
        "ID": "QmcFmLd5ySfk2WZuJ1mfSWLDjdmHZq7rSAua4GoeSQfs1z"
        "Addrs": [
          "/dnsaddr/node-3.ingress.cloudflare-ipfs.com"
        "ID": "QmcfFmzSDVbwexQ9Au2pt5YEXHK5xajwgaU6PpkbLWerMa"
        "Addrs": [
          "/dnsaddr/node-4.ingress.cloudflare-ipfs.com"
        "ID": "QmcfJeB3Js1FG7T8YaZATEiaHqNKVdQfybYYkbT1knUswx"
        "Addrs": [
          "/dnsaddr/node-5.ingress.cloudflare-ipfs.com"
        "ID": "QmcfVvzK4tMdFmpJjEKDUoqRgP4W9FnmJoziYX5GXJJ8eZ"
        "Addrs": [
          "/dnsaddr/node-6.ingress.cloudflare-ipfs.com"
        "ID": "QmcfZD3VKrUxyP9BbyUnZDpbqDnT7cQ4WjPP8TRLXaoE7G"
        "Addrs": [
          "/dnsaddr/node-7.ingress.cloudflare-ipfs.com"
        "ID": "QmcfZP2LuW4jxviTeG8fi28qjnZScACb8PEgHAc17ZEri3"
        "Addrs": [
          "/dnsaddr/node-8.ingress.cloudflare-ipfs.com"
        "ID": "QmcfgsJsMtx6qJb74akCw1M24X1zFwgGo11h1cuhwQjtJP"
        "Addrs": [
          "/dnsaddr/node-9.ingress.cloudflare-ipfs.com"
        "ID": "Qmcfr2FC7pFzJbTSDfYaSy1J8Uuy8ccGLeLyqJCKJvTHMi"
        "Addrs": [
          "/dnsaddr/node-10.ingress.cloudflare-ipfs.com"
        "ID": "QmcfR3V5YAtHBzxVACWCzXTt26SyEkxdwhGJ6875A8BuWx"
        "Addrs": [
          "/dnsaddr/node-11.ingress.cloudflare-ipfs.com"
        "ID": "Qmcfuo1TM9uUiJp6dTbm915Rf1aTqm3a3dnmCdDQLHgvL5"
        "Addrs": [
          "/dnsaddr/node-12.ingress.cloudflare-ipfs.com"
        "ID": "QmcfV2sg9zaq7UUHVCGuSvT2M2rnLBAPsiE79vVyK3Cuev"
        "Addrs": [
          "/dnsaddr/ipfs.ssi.eecc.de"
        "ID": "12D3KooWGaHbxpDWn4JVYud899Wcpa4iHPa3AMYydfxQDb3MhDME"
        "Addrs": [
          "/ip4/104.210.43.77"
        "ID": "QmR69wtWUMm1TWnmuD4JqC1TWLZcc8iR2KrTenfZZbiztd"
        "Addrs": [
          "/ip4/78.46.108.24"
        "ID": "12D3KooWGASC2jm3pmohEJXUhuStkxDitPgzvs4qMuFPaiD9x1BA"
        "Addrs": [
          "/ip4/65.109.19.136"
        "ID": "12D3KooWRbWZN3GvLf9CHmozq4vnTzDD4EEoiqtRJxg5FV6Gfjmm"
        "Addrs": [
          "/ip4/5.161.92.43/udp/4001/quic"
        "ID": "12D3KooWFFhc8fPYnQXdWBCowxSV21EFYin3rU27p3NVgSMjN41k"
        "Addrs": [
          "/ip4/5.161.92.43/tcp/4001"
        "Addrs": [
          "/ip4/5.161.55.227/tcp/4001"
        "ID": "12D3KooWSW4hoHmDXmY5rW7nCi9XmGTy3foFt72u86jNP53LTNBJ"
        "Addrs": [
          "/ip4/5.161.55.227/udp/4001/quic"
        "Addrs": [
          "/ip4/5.161.92.36/tcp/4001"
        "ID": "12D3KooWSDj6JM2JmoHwE9AUUwqAFUEg9ndd3pMA8aF2bkYckZfo"
        "Addrs": [
          "/ip4/5.161.92.36/udp/4001/quic"
  "Pinning": {
    "RemoteServices": {}
  "Plugins": {
    "Plugins": null
  "Provider": {
    "Strategy": ""
  "Pubsub": {
    "DisableSigning": false,
    "Router": ""
  "Reprovider": {},
  "Routing": {
    "Methods": null,
    "Routers": null,
    "Type": "dhtclient"
  "Swarm": {
    "AddrFilters": null,
    "ConnMgr": {
      "HighWater": 2000
    "DisableNatPortMap": false,
    "RelayClient": {},
    "RelayService": {},
    "ResourceMgr": {
      "Limits": {}
    "Transports": {
      "Multiplexers": {},
      "Network": {},
      "Security": {}
and this is my datastore_spec file
{"mounts":[{"bucket":"dev-ipfs-cluster","mountpoint":"/blocks","region":"us-east-1","rootDirectory":"/"},{"mountpoint":"/","path":"datastore","type":"levelds"}],"type":"mount"}
@stebalien
and when running ipfs repo stat getting
  "API": {
    "HTTPHeaders": {
        "PUT",
        "POST"
  "Addresses": {
    "Announce": [],
    "NoAnnounce": [],
    "Swarm": [
      "/ip6/::/tcp/4001",
  "AutoNAT": {},
  "Bootstrap": [
  "DNS": {
    "Resolvers": {}
  "Datastore": {
    "GCPeriod": "1h",
    "Spec": {
      "mounts": [
          "child": {
            "accessKey": "",
            "secretKey": "",
            "type": "s3ds"
          "type": "measure"
          "child": {
            "type": "levelds"
          "mountpoint": "/",
          "type": "measure"
      "type": "mount"
    "StorageMax": "1GB"
  "Discovery": {
    "MDNS": {
      "Enabled": true
  "Experimental": {
  "Gateway": {
    "APICommands": [],
    "HTTPHeaders": {
        "X-Requested-With",
        "Range",
        "User-Agent"
        "GET"
    "NoDNSLink": false,
    "NoFetch": false,
    "PathPrefixes": [],
    "RootRedirect": ""
  "Identity": {
  "Internal": {},
  "Ipns": {
  "Migration": {
    "Keep": ""
  "Mounts": {
    "IPFS": "/ipfs",
    "IPNS": "/ipns"
  "Peering": {
    "Peers": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
          "/ip4/78.46.108.24"
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
        "Addrs": [
  "Pinning": {
  "Plugins": {
    "Plugins": null
  "Provider": {
    "Strategy": ""
  "Pubsub": {
    "Router": ""
  "Reprovider": {},
  "Routing": {
    "Methods": null,
    "Routers": null,
    "Type": "dhtclient"
  "Swarm": {
    "ConnMgr": {
      "HighWater": 2000
    "RelayClient": {},
    "RelayService": {},
    "ResourceMgr": {
      "Limits": {}
    "Transports": {
      "Multiplexers": {},
      "Network": {},
      "Security": {}
and here is my datastore_spec file
Do you know who best to point them to for this issue? I just met with them at ETHWaterloo, they have a handful of buckets, and really want gc to work. Other than this issue they’ve had good success with using the go-ds-s3 plugin.
out of curiosity, did they ever get error like this Error: failed to enqueue CID: shutting down when using go-ds-s3 plugin ?
