I have two IPFS-clusters deployed on a separate AWS EKS clusters. For simplicity, let’s call them Alice (main, bootstrapping) and Bob.
I attached AWS LoadBalancer to the Alice cluster and Bob cluster successfully connects to it.
When I run ipfs-cluster-ctl id command on the Bob cluster I see the following addresses:
12D3KooWPsWurnD9SKVCERyeNcfJQhRnoBoWkc4rEwmdQugucGaT | itn-cluster-follow | Sees 1 other peers
> Addresses:
- /dns4/<alice-domain>/tcp/9096/p2p/12D3KooWG5uRjZFYrfPYBqZye6qv7xawYANo6vcANxSVspG5pDZH/p2p-circuit/p2p/12D3KooWPsWurnD9SKVCERyeNcfJQhRnoBoWkc4rEwmdQugucGaT
- /ip4/127.0.0.1/tcp/9096/p2p/12D3KooWPsWurnD9SKVCERyeNcfJQhRnoBoWkc4rEwmdQugucGaT
- /ip4/192.168.121.233/tcp/9096/p2p/12D3KooWPsWurnD9SKVCERyeNcfJQhRnoBoWkc4rEwmdQugucGaT
- /ip4/<alice-ip-1>/tcp/9096/p2p/12D3KooWG5uRjZFYrfPYBqZye6qv7xawYANo6vcANxSVspG5pDZH/p2p-circuit/p2p/12D3KooWPsWurnD9SKVCERyeNcfJQhRnoBoWkc4rEwmdQugucGaT
- /ip4/<alice-ip-2>/tcp/9096/p2p/12D3KooWG5uRjZFYrfPYBqZye6qv7xawYANo6vcANxSVspG5pDZH/p2p-circuit/p2p/12D3KooWPsWurnD9SKVCERyeNcfJQhRnoBoWkc4rEwmdQugucGaT
It seems like the Bob cluster uses Alice cluster as a circuit relay.
My questions are:
- Is it ok that Bob does not have its own external addresses and uses Alice as a relay?
- Is there any way to specify external addresses for IPFS-Cluster, like
announceaddresses inlibp2p? - If I connect for example 100 clusters to one bootstrapping cluster, does it mean that all network communication goes through bootstrapping peer (since it become a circuit relay for 100 clusters)?
