Hi everyone,
I have a k8s cluster running several pods, each with IPFS nodes running within - in order to peer explicitly with a single IPFS container from outside the cluster, we came up with a combination of pod cluster ip + pod cluster port along with some rules to prevent these pods from being moved around on restart. Using this information we have successfully peered within the cluster itself.
Which looks something like this:
$ ks describe pod ipfs-1 | grep Node:
Node: ip-192-xyz…us-west-2.compute.internal/192-xyz
$ k describe node ip-192-xyz…us-west-2.compute.internal | grep ExternalIP:
ExternalIP: 44.222.33.555
$ ks get svc | grep ipfs-1
ipfs-1 NodePort 10.100.180.231 4001:32639/TCP,5001:32058/TCP, 80m
Putting it all together,
ipfs//tcp//ipfs/
/ip4/44.222.33.555/tcp/32639/ipfs/QmVyKLpva…
^Peering with the above multiaddress from outside the cluster works perfectly.
However, this means that propagation to the public gateways is…still an issue since the announced value of ‘ipfs id’ contains an internal value. Explicit attempts to call ‘ipfs dht provide ’ are still not propagated externally.
Ex. of ips id:
“/ip4/127.0.0.1/tcp/4001/ipfs/QmVyKLpva…”,
“/ip4/192.168.3.7/tcp/4001/ipfs/QmVyKLpva…”
Is there a recommended approach for this specific scenario?
jimpick
September 12, 2019, 2:14pm
2
You could set to set your “Announce” address to “/ip4/44.222.33.555/tcp/32639/ipfs/QmVyKLpva…” in the Addresses section of the IPFS config file.
# The go-ipfs config file
The go-ipfs config file is a JSON document located at `$IPFS_PATH/config`. It
is read once at node instantiation, either for an offline command, or when
starting the daemon. Commands that execute on a running daemon do not read the
config file at runtime.
#### Profiles
Configuration profiles allow to tweak configuration quickly. Profiles can be
applied with `--profile` flag to `ipfs init` or with the `ipfs config profile
apply` command. When a profile is applied a backup of the configuration file
will be created in `$IPFS_PATH`.
Available profiles:
- `server`
Recommended for nodes with public IPv4 address (servers, VPSes, etc.),
disables host and content discovery in local networks.
This file has been truncated. show original
Thanks for the help Jim! This actually worked perfectly for what we needed to do!
Minor note is that the Announce config doesn’t expect peerID:
“Announce”: ["/ip4/44.222.33.555/tcp/32639"] is what worked
I’m trying something similar, but running into an error about “failed to negotiate security protocol”.
First I tried using a GCP LoadBalancer service in order to preserve the 4001 port.
I update the Announce address with the LoadBalancer address:
/ # ipfs swarm addrs local
/ip4/35.223.117.213/tcp/4001
Then, from another node:
$ ipfs dht findpeer Qmb4n3WteiFydckcw8bCpgmi7xXU6F8hweDddUaxwJXeau
$ ipfs swarm connect /ip4/35.223.117.213/tcp/4001/ipfs/Qmb4n3WteiFydckcw8bCpgmi7xXU6F8hweDddUaxwJXeau
Error: connect Qmb4n3WteiFydckcw8bCpgmi7xXU6F8hweDddUaxwJXeau failure: failed to dial : all dials failed
[/ip4/35.223.117.213/tcp/4001] failed to negotiate security protocol: read tcp4 165.22.38.112:4001->35.223.117.213:4001: read: connection reset by peer
So, I switched to a NodePort, and updated the Announce config
/ip4/104.197.190.12/tcp/30641
$ ipfs swarm connect /ip4/104.197.190.12/tcp/30641/ipfs/Qmb4n3WteiFydckcw8bCpgmi7xXU6F8hweDddUaxwJXeau
[/ip4/104.197.190.12/tcp/30641] failed to negotiate security protocol: read tcp4 165.22.38.112:4001->
104.197.190.12:30641: read: connection reset by peer
Any idea what’s failing to negotiate and why my kubernetes node is resetting the connection?
Thanks!
Ben
kiftio
August 14, 2020, 9:53am
5
Hey Ben, did you manage to resolve the issue? I’m hitting the same problem.
No, I designed around this instead and used a non-kubernetes cluster for public connections.
I’ve been meaning to retry with the new release (and know that I know a bit more).
kiftio
August 14, 2020, 2:02pm
7
In case it’s useful, I’ve been able to swarm connect successfully after changing the externalTrafficPolicy on the NodePort to Local.
Some more info on that:
Applications running in a Kubernetes cluster find and communicate with each other, and the outside world, through the Service abstraction. This document explains what happens to the source IP of packets sent to different types of Services, and how...
