How to disable UPnP? In go-ipfs, and also in other apps that use it (openbazaar)?
Even after manually opening a port, libp2p still punches the same port on the router via UPnP.
I don’t think there’s a switch to do it in go-ipfs. If there aren’t any applications you want to use UPnP, it might be easier to disable UPnP on your router.
edit: I was wrong. See below.
The following should do it:
ipfs config --json 'Swarm.DisableNatPortMap' true
Thanks. This worked for openbazaar too. Dunno how I missed it when reading through the config looking for it.
Because our documentation is sorely lacking? Documentation improvements are always welcome!
