If another instance of the daemon is not running you can clean up the lock files using ipfs repo fsck before trying to start the daemon again after getting this error.
Thanks John suggesting solution. But once again i stuck at another place. I am submitting 4 screen shots here.
- First of after using ipfs repo fsck command.
- when i click http://localhost:5001/webui
Unless there’s a permissions issue, the “access denied” errors are likely due to this issue and should be resolved in the next release.
If the daemon isn’t running due to the lock file error, then the webui won’t load. The daemon needs to be running for the webui to be accessible.
