Implementing Helia
Super Excited for this to reduce dependency on gateways to communicate to nodes via the browser.
I have a couple questions in the implementation. It seems the networking example is set up using tcp which doesn’t work for in browser. I found an example in the libp2p library on how to setup web transports but it is seemingly outdated since connectionManager is no longer existing. See here for reference: js-libp2p/index.js at master · libp2p/js-libp2p · GitHub
Also it results in alot of peers being found but being unable to dial to it.
Still abit new to this but is there a example project that shows helia connecting to a kubo node via webTransport and what is required to properly configure the libp2p? Just trying to be able to run cat on a CID and direct connect to a node that I know has the data I need. Currently at IPFS thing as well.
We just made this: GitHub - libp2p/universal-connectivity
Does the repo help you? If you need any help getting it up-and-running let me know.
A little bit! will have to dive more into it
Did you find a way to setup libp2p with web transport? I am trying but I don,t understand, could you share your solution? Thanks a lot
FYI: the libp2p setup for Helia is fairly straightforward:
but most of that comes from Helia’s default libp2p config for the browser: https://github.com/ipfs/helia/blob/main/packages/helia/src/utils/libp2p-defaults.browser.ts
As far as configuring Kubo to announce webtransport addresses, I believe any issues there have been fixed since I last updated my IPFS config, but here’s my config if it helps:
> npx -y kubo config show
  "API": {
    "HTTPHeaders": {
        "PUT",
        "POST"
        "http://localhost:3000",
        "http://127.0.0.1:5001",
        "https://webui.ipfs.io",
        "http://localhost:5173"
  "Addresses": {
    "Announce": [],
    "AppendAnnounce": [
      "/ip4/0.0.0.0/udp/4001/quic",
      "/ip4/0.0.0.0/udp/4001/quic-v1/webtransport"
    "Gateway": "/ip4/127.0.0.1/tcp/8081",
    "NoAnnounce": [],
    "Swarm": [
      "/ip4/0.0.0.0/tcp/4001",
      "/ip6/::/tcp/4001",
      "/ip6/::/udp/4001/quic",
      "/ip6/::/udp/4001/quic-v1",
  "AutoNAT": {},
  "Bootstrap": [
    "/ip4/104.131.131.82/udp/4001/quic/p2p/QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ"
  "DNS": {
    "Resolvers": {}
  "Datastore": {
    "BloomFilterSize": 0,
    "GCPeriod": "1h",
    "HashOnRead": false,
    "Spec": {
      "mounts": [
          "child": {
            "path": "blocks",
            "sync": true,
            "type": "flatfs"
          "mountpoint": "/blocks",
          "prefix": "flatfs.datastore",
          "type": "measure"
          "child": {
            "compression": "none",
            "path": "datastore",
            "type": "levelds"
          "mountpoint": "/",
          "type": "measure"
      "type": "mount"
    "StorageGCWatermark": 90,
    "StorageMax": "10GB"
  "Discovery": {
    "MDNS": {
      "Enabled": true
  "Experimental": {
    "FilestoreEnabled": false,
    "GraphsyncEnabled": false,
    "OptimisticProvide": false,
    "P2pHttpProxy": false,
    "StrategicProviding": false,
    "UrlstoreEnabled": false
  "Gateway": {
    "APICommands": [],
    "DeserializedResponses": null,
    "HTTPHeaders": {
        "X-Requested-With",
        "Range",
        "User-Agent"
        "GET"
    "NoDNSLink": false,
    "NoFetch": false,
    "PathPrefixes": [],
    "PublicGateways": null,
    "RootRedirect": "",
    "Writable": false
  "Identity": {
    "PeerID": "REDACTED"
  "Internal": {},
  "Ipns": {
    "RecordLifetime": "",
    "RepublishPeriod": "",
    "ResolveCacheSize": 128
  "Migration": {
    "DownloadSources": [],
    "Keep": ""
  "Mounts": {
    "FuseAllowOther": false,
    "IPFS": "/ipfs",
    "IPNS": "/ipns"
  "Peering": {
    "Peers": null
  "Pinning": {
    "RemoteServices": {
      "4EVERLAND": {
        "API": {
          "Endpoint": "https://api.4everland.dev"
        "Policies": {
          "MFS": {
            "Enable": false,
            "PinName": "",
            "RepinInterval": ""
  "Plugins": {
    "Plugins": null
  "Provider": {
    "Strategy": ""
  "Pubsub": {
    "DisableSigning": false,
    "Router": ""
  "Reprovider": {},
  "Routing": {
    "Methods": null,
    "Routers": null
  "Swarm": {
    "AddrFilters": null,
    "ConnMgr": {},
    "DisableNatPortMap": true,
    "RelayClient": {},
    "RelayService": {},
    "ResourceMgr": {
      "Allowlist": [],
      "Enabled": true,
      "Limits": {}
    "Transports": {
      "Multiplexers": {},
      "Network": {},
      "Security": {}
Note that webtransport does not seem to be listening publicly (for Kubo) unless I set my public IP address in Addresses.AppendAnnounce manually. I thought this to have been resolved with fix: fix externally defined webtransport addresses by aschmahmann · Pull Request #2224 · libp2p/go-libp2p · GitHub, but it doesn’t appear to be resolved. When I remove my public IP from AppendAnnounce, my listening Multiaddrs do not list anything except private IPs: 127.0.0.1, 192.168.1.227, ::1, etc…
