- OS: MacOS
- Version of IPFS Desktop v2.13.0
Describe the bug
Hello, I am trying to develop a NodeJS API which enables users to interact with an IPFS node owned by the API.
What I want to do is for testing purposes to verify that when I programmatically pin a new file, this one is currently retrieved and pinned on the node I create in my NodeJS code.
I also expect that shutting down and restarting the NodeJS code won’t have an impact on data persistence as it will always look at the same folder (~/.jsipfs).
I have a very hard time to use the IPFS Desktop as a dashboard to see the current state of my jsipfs node running with my API.
I tried following the instructions from the UI that is displayed when no connection can be established but without success.
I also tried to connect using /ip4/127.0.0.1/tcp/4002 instead of 5001 as proposed, because my code displays the 4003 and 4002 ports as the one being used.
I tried changing the config file of ipfs-desktop in order to point to my .jsipfs folder instead of .ipfs.
I can’t even use the cli command jsipfs repo stat as an alternative to ipfs-desktop as the folder is already locked by my API.
To Reproduce
Steps to reproduce the behavior:
- Start a daemon from JS with for example :
import * as IPFS from "ipfs-core"
const node = await IPFS.create()
- If you try any command with the jsipfs cli like
jsipfs repo statyou will be refused access, which confirms the node runs well. - Edit the config file of ipfs-desktop to make it point to the jsipfs repo. Especially change these two lines :
"ipfsConfig": {
"type": "js",
"path": "/Users/nex/.jsipfs",
- Start ipfs-desktop
- It should not be able to connect to the node
Expected behavior
I expect the UI to be a reflection of the repo that is hosted in the .jsipfs folder. When a file is added from JS for example, it should be seen on the IPFS Desktop UI.
Additional context
My issue seem very common but I couldn’t find anything related when searching on internet.
I am sorry if the solution is trivial.
Thank you for your help.
