I’m using IPFS with Vue but cannot get the app to start because of a dependency error.
I have a very simple setup:
vue create my-project
cd my-project
npm install ipfs
Import ipfs in some component:
import * as IPFS from "ipfs";
and run
npm run serve
and it will error with:
This dependency was not found: * ipfs in ./node_modules/cache-loader/dist/cjs.js??ref--13-0!./node_modules/babel-loader/lib!./node_modules/cache-loader/dist/cjs.js??ref--1-0!./node_modules/vue-loader/lib??vue- loader-options!./src/components/ProfileEditor.vue?vue&type=script&lang=js&
To install it, you can run: npm install --save ipfs
However, I already have ipfs installed.
I can get this working with vanilla node but for some reason vue cannot load this package.
So, yes, I’m able to get the vue example running and I’m also able to use ipfs-core from a vanilla node install. However, I’m confused why I can’t simply get IPFS running by installing the package and then importing it. Comparing my out-of-the-box vue project with the example suggests the only difference is importing the minimal package ipfs-core. I tried this but got another round of dependency issues:
These dependencies were not found:
* @libp2p/crypto/keys in ./node_modules/ipfs-core/src/components/storage.js, ./node_modules/ipfs-core/src/components/name/publish.js and 1 other
* @libp2p/interfaces/peer-id in ./node_modules/ipfs-core/src/components/storage.js, ./node_modules/ipfs-core/src/ipns/publisher.js
* @libp2p/logger in ./node_modules/ipfs-core/src/preload.js, ./node_modules/ipfs-core/src/components/index.js and 8 others
* @libp2p/peer-id in ./node_modules/ipfs-core/src/components/resolve.js, ./node_modules/ipfs-core/src/components/name/publish.js and 2 others
* @libp2p/peer-id-factory in ./node_modules/ipfs-core/src/components/storage.js
* @libp2p/record in ./node_modules/ipfs-core/src/ipns/routing/offline-datastore.js
* @libp2p/topology in ./node_modules/ipfs-bitswap/src/network.js
This would suggest some kind of import error (maybe webpack related) because those packages are available but it seems they are not getting imported.
Migrating an existing vue app to a browser-vue-based example boilerplate is not really viable unfortunately.
I’m not sure why simply installing ipfs and then importing is creating so many dependency errors. It must be a configuration issue but where?
Looking into this further, it seems to be some kind of import misconfiguration, for example, this import error:
@libp2p is installed and crypto/keys exists under @libp2p/crypto/src/keys. I suspect the “src” is causing the problem but am unsure how to resolve.
So, turns out I was setting up my project incorrectly in Vue. Running npm init vue@3 (or vue@2) is the correct way to deploy a new project. Doing this and installing ipfs-core gets rid of the above error and opens up a whole new list of errors:
ERROR] Big integer literals are not available in the configured target environment ("chrome87", "edge88", "es2020", "firefox78", "safari13" + 2 overrides)
node_modules/ipfs-core/src/ipns/publisher.js:193:20:
193 │ let seqNumber = 0n
All errors are related to this lack of support for native big number and my understanding is esNext addresses it. However, I’m at a loss how to fix.
browser-external:util:9 Uncaught Error: Module "util" has been externalized for browser compatibility. Cannot access "util.inherits" in client code.
I’m at a loss as to how I can’t just install the ipfs package and start using it, a la the documentation. This is feeling like it is fundamentally broken.
