Thanks @wclayf for taking the time,
I can access SimpleHTTPServer through SSH port forwarding. I can also access the ipfs daemon by running the above SSH command. E.g. the following command on my local computer gives me a response from the daemon:
$ curl localhost:5001
404 page not found
the ipfs cat command still doesn’t work.
To recap
- Remote: IPFS daemon API is running on port 5001
- Local: SSH forward via
ssh -NL 5001:localhost:5001 my-user@my-server
- Remote:
curl localhost:5001 returns 404 page not found (would return “Connection refused” if daemon were not running)
- Local:
curl localhost:5001 returns 404 page not found - evidence for port forward
- Remote
ipfs cat QmY7Yh4UquoXHLPFo2XbhXkhBvFoPwmQUSa92pxnxjQuPU returns data
- Local:
ipfs cat QmY7Yh4UquoXHLPFo2XbhXkhBvFoPwmQUSa92pxnxjQuPU returns Error: merkledag: not found
- Local:
ipfs config show:
"API": {
"HTTPHeaders": {}
"Addresses": {
"Announce": [],
"NoAnnounce": [],
"Swarm": [
"/ip4/0.0.0.0/tcp/4001",
"/ip6/::/tcp/4001",
"/ip4/0.0.0.0/udp/4001/quic",
"/ip6/::/udp/4001/quic"
"AutoNAT": {},
"Bootstrap": [
"/ip4/104.131.131.82/udp/4001/quic/p2p/QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ",
"/dnsaddr/bootstrap.libp2p.io/p2p/QmbLHAnMoJPWSCR5Zhtx6BHJX9KiKNN6tpvbUcqanj75Nb"
"Datastore": {
"BloomFilterSize": 0,
"GCPeriod": "1h",
"HashOnRead": false,
"Spec": {
"mounts": [
"child": {
"path": "blocks",
"sync": true,
"type": "flatfs"
"mountpoint": "/blocks",
"prefix": "flatfs.datastore",
"type": "measure"
"child": {
"compression": "none",
"path": "datastore",
"type": "levelds"
"mountpoint": "/",
"type": "measure"
"type": "mount"
"StorageGCWatermark": 90,
"StorageMax": "10GB"
"Discovery": {
"MDNS": {
"Enabled": true,
"Interval": 10
"Experimental": {
"FilestoreEnabled": false,
"GraphsyncEnabled": false,
"P2pHttpProxy": false,
"ShardingEnabled": false,
"StrategicProviding": false,
"UrlstoreEnabled": false
"Gateway": {
"APICommands": [],
"HTTPHeaders": {
"X-Requested-With",
"Range",
"User-Agent"
"GET"
"NoDNSLink": false,
"NoFetch": false,
"PathPrefixes": [],
"PublicGateways": null,
"RootRedirect": "",
"Writable": false
"Identity": {
"PeerID": "my-peer-id"
"Ipns": {
"RecordLifetime": "",
"RepublishPeriod": "",
"ResolveCacheSize": 128
"Mounts": {
"FuseAllowOther": false,
"IPFS": "/ipfs",
"IPNS": "/ipns"
"Peering": {
"Peers": null
"Plugins": {
"Plugins": null
"Provider": {
"Strategy": ""
"Pubsub": {
"DisableSigning": false,
"Router": ""
"Reprovider": {
"Interval": "12h",
"Strategy": "all"
"Routing": {
"Type": "dht"
"Swarm": {
"AddrFilters": null,
"ConnMgr": {
"GracePeriod": "20s",
"HighWater": 900,
"LowWater": 600,
"Type": "basic"
"DisableNatPortMap": false,
"EnableAutoRelay": false,
"EnableRelayHop": false,
"Transports": {
"Multiplexers": {},
"Network": {},
"Security": {}
