Hello,
I have a situation where I deployed my own private IPFS cluster containing 4 nodes. I uploaded a file using a replication factor of 2, and I also specified 2 nodes using the user-allocations parameter. The file was pinned correctly, as the ipfs-cluster-ctl status command showed it as PINNED on the 2 specified nodes.
Later, one of the specified nodes went down, and the pin was automatically transferred to another available IPFS node to maintain the replication factor. So far, this behavior is expected.
Now, I want to bring the originally specified node back up. However, the IPFS cluster does not automatically repin the file to that node. In other words, I no longer see PINNED for that node in the status output.
Is this expected behavior, or is there something I need to adjust in the configuration? Are there any workarounds or ideas for how I can return the pin to the original node from the temporary one?
