Difference between ipfs pin add and ipfs get
hi zhjgit
ipfs pin add pin a hash into your DHT
ipfs get add into your DHT and get content of this hash
Regards
ipfs pin addfetches the file, adds it to your local IPFS file repository “repo”, and then “pins” it (keeps it from being deleted if you run low on space). -
ipfs getfetches the file, adds it to your local IPFS repo, does not pin it, and then saves it to your local filesystem.
Basically, ipfs pin add is like ipfs get followed by an ipfs add.
So, both commands will announce that you have the file to the DHT. However, it won’t add the content to the DHT.
