IPFS Companion Chrome Extension v3.0.0
Mac OSX 12.6
Chrome Version 116.0.5845.187
After recent update to v3.0.0, IPFS companion always shown “PEER offline”, as below:
@ssghost are you running the latest kubo docker image?
Tested docker run --rm -it --net=host ipfs/kubo:v0.22.0 with Google Chrome 117.0 and Companion v3.0.0 works fine:
If you prefer to use latest tag, try switching to ipfs/kubo:latest and make sure you run the latest version (docker pull ipfs/kubo:latest)
Hello, I tried ipfs/kubo:latest this Docker contanier and deployed it normally but the IPFS companion extension is still the same, no peers connection at all.
I searched the official IPFS Kubo Doc and found the “docker run” command that @lidel provided is incomplete and it did not generate a P2P port connection for the Docker container at all. The complete form of “docker run” command should be like:
