On MacOS 10.14, daemon is running.
Running findprovs takes forever.
See below.
Is it in some way the expected behavior?
Thanks,
J
$ ipfs dht findprovs QmTtHTDZK3tnDFTmnSzbjnQ2TnMVj6arSB88Lv1UywmsYs --v
18:58:48.139: adding peer to query: <peer.ID Qm*NchesU>
18:58:48.139: adding peer to query: <peer.ID Qm*ooxpN1>
18:58:48.140: adding peer to query: <peer.ID Qm*NPxumv>
18:59:11.040: error: dial attempt failed: <peer.ID Qm*XecMc5> --> <peer.ID Qm*qRZ2BK> dial attempt failed: context deadline exceeded
18:59:11.947: * <peer.ID Qm*u6u3hN> says use <peer.ID Qm*z7Aq6w> <peer.ID Qm*TE1mR4> <peer.ID Qm*piKrTo> <peer.ID Qm*bVe9MZ> <peer.ID Qm*h8WHMC> <peer.ID Qm*tUWvXZ> <peer.ID Qm*H9aKwK> <peer.ID Qm*kYLNhz> <peer.ID Qm*Ew4txY> <peer.ID Qm*Uq76N9> <peer.ID Qm*dr9WGk> <peer.ID Qm*vx4xYt> <peer.ID Qm*5xxm9x> <peer.ID Qm*87Bhiw> <peer.ID Qm*MMtNG3> <peer.ID Qm*hsqpek> <peer.ID Qm*NchesU> <peer.ID Qm*LzMYsx> <peer.ID Qm*qRZ2BK> <peer.ID Qm*mABKvG>
18:59:11.947: * querying <peer.ID Qm*Ga4f2W>
19:00:33.553: * querying <peer.ID Qm*ej6JaC>
19:00:36.233: * <peer.ID Qm*ej6JaC> says use <peer.ID Qm*yY8bzi> <peer.ID Qm*79G8eR> <peer.ID Qm*Gb9ytQ> <peer.ID Qm*kdJy6u> <peer.ID Qm*GoSh1j> <peer.ID Qm*EXSMFJ> <peer.ID Qm*saJKpA> <peer.ID Qm*piKrTo> <peer.ID Qm*H9aKwK> <peer.ID Qm*mBVj7P> <peer.ID Qm*zb3yST> <peer.ID Qm*Ew4txY> <peer.ID Qm*WRQM2d> <peer.ID Qm*wYtCFt> <peer.ID Qm*31YG4D> <peer.ID Qm*RxXYSN> <peer.ID Qm*Qxhox7> <peer.ID Qm*2qULxV> <peer.ID Qm*58RYV2> <peer.ID Qm*3zpG3T>
19:00:36.233: * querying <peer.ID Qm*i6eTLk>
19:00:36.751: * <peer.ID Qm*i6eTLk> says use <peer.ID Qm*V4TM5d> <peer.ID Qm*pQXHpP> <peer.ID Qm*yY8bzi> <peer.ID Qm*Lj65wJ> <peer.ID Qm*Cv5GhR> <peer.ID Qm*kdJy6u> <peer.ID Qm*GoSh1j> <peer.ID Qm*EXSMFJ> <peer.ID Qm*saJKpA> <peer.ID Qm*TE1mR4> <peer.ID Qm*piKrTo> <peer.ID Qm*mBVj7P> <peer.ID Qm*Ew4txY> <peer.ID Qm*2y8Xco> <peer.ID Qm*WRQM2d> <peer.ID Qm*87Bhiw> <peer.ID Qm*wYtCFt> <peer.ID Qm*RxXYSN> <peer.ID Qm*Qxhox7> <peer.ID Qm*2qULxV>
19:00:36.752: adding peer to query: <peer.ID Qm*2y8Xco>
19:00:36.753: * querying <peer.ID Qm*XjZabi>
19:01:09.899: error: dial attempt failed: <peer.ID Qm*XecMc5> --> <peer.ID Qm*LjN27r> dial attempt failed: context deadline exceeded
19:01:09.899: error: dial attempt failed: <peer.ID Qm*XecMc5> --> <peer.ID Qm*Zf611c> dial attempt failed: context deadline exceeded
19:01:10.118: error: dial attempt failed: <peer.ID Qm*XecMc5> --> <peer.ID Qm*57Gd6U> dial attempt failed: context deadline exceeded
19:01:10.118: error: dial attempt failed: <peer.ID Qm*XecMc5> --> <peer.ID Qm*xnvzPT> dial attempt failed: context deadline exceeded
19:03:38.582: adding peer to query: <peer.ID Qm*dUeLxm>
19:03:38.582: dialing peer: <peer.ID Qm*dUeLxm>
19:03:38.582: * querying <peer.ID Qm*geyee2>
19:03:39.025: * <peer.ID Qm*geyee2> says use <peer.ID Qm*pQXHpP> <peer.ID Qm*tvenyL> <peer.ID Qm*EXSMFJ> <peer.ID Qm*piKrTo> <peer.ID Qm*uSgHyj> <peer.ID Qm*8pJWpV> <peer.ID Qm*ijMSbC> <peer.ID Qm*58RYV2> <peer.ID Qm*3zpG3T> <peer.ID Qm*VQKNAd> <peer.ID Qm*NPxumv> <peer.ID Qm*1Ttyr2> <peer.ID Qm*dN43K4> <peer.ID Qm*BxyqRw> <peer.ID Qm*HREVY4> <peer.ID Qm*ej6JaC> <peer.ID Qm*j61Zxu> <peer.ID Qm*SUEYAt> <peer.ID Qm*JuiFZu> <peer.ID Qm*wgsxdt>
19:03:39.025: dialing peer: <peer.ID Qm*5mKGYs>
19:03:39.025: dialing peer: <peer.ID Qm*7XtUJY>
19:03:39.026: dialing peer: <peer.ID Qm*aQPDLQ>
19:03:39.026: error: dial attempt failed: failed to dial <peer.ID Qm*5mKGYs> (default failure)
19:03:39.026: error: dial attempt failed: failed to dial <peer.ID Qm*7XtUJY> (default failure)
19:03:39.026: dialing peer: <peer.ID Qm*TMyP7v>
19:03:39.026: * querying <peer.ID Qm*jYyXRW>
19:03:41.822: error: dial attempt failed: <peer.ID Qm*XecMc5> --> <peer.ID Qm*JtuwYQ> dial attempt failed: context deadline exceeded
19:03:42.163: error: dial attempt failed: <peer.ID Qm*XecMc5> --> <peer.ID Qm*Uc1YxM> dial attempt failed: context deadline exceeded
19:03:43.581: error: dial attempt failed: <peer.ID Qm*XecMc5> --> <peer.ID Qm*dUeLxm> dial attempt failed: context deadline exceeded
