Greetings,
I have recently set up a go-ipfs node for testing as a gateway. I have been able to add files locally on the server, and read them remotely in the browser, as well as in code (C#, .Net and the Ipfs.Http.Client library). However, trying to add a file from a remote machine, using http://mynode/api/v0/add fails with a 404 error.
I have set “Writeable”: true in the config file, and the daemon indicates that it is writeable on startup.
The request looks like this
POST /api/v0/add?chunker=size-262144 HTTP/1.1
User-Agent: net-ipfs/0.33
Accept-Encoding: gzip, deflate
Content-Type: multipart/form-data; boundary=“3ac6737d-2600-454f-ae91-9a5713b2c22b”
Content-Length: 227
Host: myrealhostaddress:8080
–3ac6737d-2600-454f-ae91-9a5713b2c22b
Content-Type: application/octet-stream
Content-Disposition: form-data; name=file; filename=unknown; filename*=utf-8’'unknown
This is a test
–3ac6737d-2600-454f-ae91-9a5713b2c22b–
Has anyone experienced this behavior, or does anyone have any ideas on how to begin diagnosing this problem?
Thanks,
Chris
